Right angle TNC connector
alcladrv
Has anybody used a right angle TNC connector on RG400 coax to connect to their WAAS GPS antenna? If so, which part number did you use?
Thanks, Mike
L-com
I'd like to put in a plug (no pun intended) for L-com. They've got all kinds of connectors, adapters, coax, and custom cables. I'm not affiliated with them in any way but have been a customer for many years. http://www.l-com.com/
I would suggest you use the adapterator....
I tried to solder one of the std ones and threw it out the window in frustration. Second only to doing micro molex :mad:
Yep it wouldn't fit without it.
Silver plated devil from Stein Air. It uses the standard crimper & technique.
