david.perl
Ive noticed a small oil leak where oil ends up coming down inside the nose leg fairing and then a small amount ends up on the nose wheel spat. This only happens after a flight and the oil is sooty / black. Whats odd is the oil has just been changed and when checking levels with the dipstick its clean.
When i changed the oil a few weeks back I couldn't see any obvious leaks.
Engine has 200 hours on it and all running parameters are fine.
Any ideas where this can be coming from?
