Ross7A-builder
Member
Drawing 16A shows a cork gasket between plate T-708 and the onboard rib (coordinates B5 and G8). However, there is no gasket on the packing list, and there was none in the wing kit when it arrived. Further, there is little discussion of gaskets in Section 7 (e.g., page 7-6 and 7-8). Are cork gaskets required? If so, how do I obtain them? Have already emailed Van?s, haven?t heard back yet.
Also, are there any more detailed instructions on attaching T-708 to the rib? The holes and directions show that they are bolted to T-407 but it looks like T-708 is riveted to the rib under the fuel sender base plate. Would appreciate clarification.
