Hi, I'm in the process of building the rv14 wing kit down under in New Zealand and have got to the aileron actuation push rods, where you drill 6 holes in the 1 1/8 6061 tubing using the template cut out. My problem is that template is to short and I know I can make my own template but my concern is the instructions say the Va-111 rod ends should be a tight slip in fit but mine are not. I know once I prime them the fit will be tighter. Just concerned because two things don't seem quite right. Has anyone else had the same issues?
Thanks in advance.
Thanks in advance.
