Gordon Martin
Member
I am trying to finish an old RV3 kit and need some help. If the straps that support the fuselage fuel tank are made according to Van's plans, there is a 4 to 5 inch section where the two sections are joined together that does not fit the round contour of the tank because of the clamp fittings, so there is a gap between the strap and the tank at that point. It seems to me it would be better if there was continuous contact with the tank. How have those of you with fuselage tanks solved that problem...or is it not a problem?
