Parking Brake installation RV-8
Anna
Active Member
Hi Volks,
I ordered the Parking Brake Valve PV2 from Vans. I thought it will also work for the RV8, since this is the only Parking Brake on the Vans-Website...
The Vans PV2 is equal to the PVPV-D from MATCO :
http://www.matcomfg.com/PARKINGBRAKEVALVEDUAL-idv-3579-8.html
Yesterday, I searched some threads and saw, that all RV8 builders use a different parking brake valve:
http://www.matcomfg.com/PARKINGBRAKEVALVE-idv-2606-8.html
Which parking brake would you recommend? How have you installed it?
Pictures or links would be very helpful...
Many thanks in advance!
Best regards,
Anna
I used the Matco like you posted, with elbows... I think both models can be made to work...
I did not hook up a Bowden cable as I can reach under the panel to operate it. I do find that the "brake on" arc is quite critical and it is easy to get one brake holding and not the other. I test it before I trust it to make sure both brakes are holding.
