Old 03-10-2017, 03:15 PM
Gandalf Gandalf is offline
Here is an update. Although the new vacuum powered Dremel drill does vacuum up the dust, it does not have enough power to easily cut the engine cowling fiberglass. Instead, I used duct tape to attach a shop vac hose to an electric Dremel with a good result. The Dremel 543 1-1/4 cutting/shaping wheel cuts like butter and seems very durable.
Old 03-11-2017, 12:01 AM
hufise hufise is offline
Hi to all Dremel friends but...
I would recommend Fine tools there is only a little dust down on the floor
Daniel
#12383
Flying over 300 hours
Old 03-11-2017, 05:51 AM
bruceflys bruceflys is offline
Default Another Dremel Cutter
Dremel makes a diamond cutting wheel that creates significantly less dust than its grit wheel. https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Bruce
RV-10 - 95% complete project For Sale
RV-12 - built for wife now flying light sport
SeaRey flying 2012 - Sold 2017
2017 Contribution made
Old 03-11-2017, 06:43 AM
DanH's Avatar
DanH DanH is online now
Shop dust is a constant battle. Keep in mind that a lot of fiberglass parts rough trim very well with a big pair of tin snips.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-11-2017, 07:22 AM
bobnoffs bobnoffs is offline
when i started on my cowl i finally bit the bullet and drilled a hole thru my shop wall into the pole barn and made my fresh air respirator a permanent fixture in my shop. and whenever i cut with any power tools i have a vac. hose in one hand. the vac must get 80-90% of the dust.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying
RV-12 kit as of 9/13
Old 03-11-2017, 08:59 AM
dtw_rv6 dtw_rv6 is offline
I like using tin snips for rough cuts as well. I've noticed that fiberglass can tend to delaminate when sheared like this, so I always make sure I'm sanding or fine grinding away enough that you have sound material in the final piece.
Don
Old 03-11-2017, 09:26 AM
snopercod's Avatar
Default rotary scissors
On my Lancair kit, I had to trim probably 100 linear feet of fiberglass. The tool of choice for doing that job was an electric tool the size of a sabre saw called "rotary shears" or "rotary scissors". The tool had two 1/8" thick hardened steel wheels which played against each other like the halves of a pair of scissors. One wheel was driven by the slow-speed motor and the other was freewheeling. The discs weren't sharp like knives rather, the edges were flat. I think this tool was designed for cutting fabric. They worked great on cured fiberglass, but I don't think they're available any more. I sold my pair long ago.
(2018 dues paid)
Old 03-11-2017, 08:49 PM
Hardly any dust with the vacuum.
And it is hard to explain: the FACE of the cutter/shaper is a shaper. Push up against the cut line and it is like using a rotary sander. So you can cut leaving a small band or residual here and there and by slightly pushing UP into the cut line you can sand off any residual material flush to the cut line.
Old 03-12-2017, 03:25 AM
Get yourself an oscillating cutter. They are the bomb for cutting fiberglass. Fein tools sells the Cadillac version but I saw a Dewalt on amazon for $130. Carpenters use them for fine cutting jobs. The vibration action makes dust that simply falls to the floor. They are similar to what hospitals use to cut casts off. Very,very safe and a kerf line ,cut line, about .032 or less.
https://www.amazon.ca/DEWALT-DCS355B...cillating+tool
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 03-12-2017, 05:34 AM
Or this, if you don't need battery operated... $32 at Home Depot
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 320
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
