  #41
Old 03-14-2017, 09:46 AM
Chattin35 Chattin35 is offline
Originally Posted by roadrunner20 View Post
IO360, 2005 catto 3 blade
Here's my morphed 7A to 7 data
7A CG = 81.88, empty weight 1081
7 CG = 81.11, empty weight 1065
Since I will be installing the landoll ring, I was looking at the data today, my cg moved forward on the conversion.
The 12# ring will help, but I will also keep my lead scuba bean bags on my inside firewall. I created a dam to hole them forward.
Very interesting. Thanks Dan.
I'm about a week away from weighing mine -- taildragger, IO-360-M1B, Hartzell BA, light VFR glass panel, built to plans. Should be interesting. I'll post the #'s when I have them.
Old 03-14-2017, 11:18 AM
rzbill's Avatar
rzbill rzbill is offline
Interesting indeed. The CG change data is counterintuitive to me.
On the assumption that there were not any other items relocated unrelated to the 7A to 7 change, the CG moving forward indicates that the main gear relocation has a major effect on CG position between the 7 and 7A.
The nose gear removal and tail wheel addition are both "rearward CG" moves so the main gear repositioning had to more than compensate for both of them.
I have had recent "idle" thoughts about converting to a 7. It will take a mighty big "round tuit" though.
When I was building 7A 10 years ago, I had seen posts about rear CG tendency but I did not realize it was the taildragger being described. I pushed everything forward during construction and have an empty CG of 78.7" which is quite far forward. It is essentially impossible for me to load the craft out the back of the envelope. Downside is my nosewheel weight is high although still within Vans limits in all loading scenarios.
For reference:
7A unpainted tip up
IO-360-M1B/Hartzell
IFR Glass w/ steam BU
Some fabric interior by SWMBO
Kevlar/ceramic floorboards
1109 lbs
78.7 empty CG
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 690hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 03-14-2017, 12:32 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Originally Posted by rzbill View Post
Interesting indeed. The data is counterintuitive to me.
For reference:
7A unpainted tip up
IO-360-M1B/Hartzell
1109 lbs
78.7 empty CG
I also have the forward induction, but mine is a Superior model. But notice, my catto prop weighs in at 18# moving my cg considerable aft
Dan "RoadRunner" Landry
Morphed RV7, N20DL, PNP Pilot
1050+ hours, hit 1000 enroute to Oshkosh
2017 Donation Paid
Old 03-24-2017, 02:31 AM
Pin 21 Pin 21 is offline
Default VH-UER
Fairly disappointed in the results from a loooong slow build (10 years)
RH main = 531
LH main = 530
Tailwheel = 75
C of G = 80.8"
Painted and ALL parts fitted. RV-7 Io-360 parallel valve, Whirlwind prop. Classic interior.
Old 03-24-2017, 06:17 AM
I installed the landoll ring last weekend.
It moved my cg forward from 81.11 to 80.48
2017 Donation Paid
Old 03-29-2017, 09:43 PM
Default N437T #'s
Quickbuild
IO-360-M1B
Hartzell BA CS Prop
VFR glass panel (dual GRT Horizons)
Classic Aero Sportsman seats
Built light and to the plans
Weighed on certified and calibrated scales
Equipped for 1st flight (see pic below)
Left: 492
Right: 494
Tail: 57
Total: 1043
Stoked!
Old 06-30-2017, 10:04 AM
EinEngineer's Avatar
EinEngineer EinEngineer is offline
Default Same problem on the -14?
Quick question from the new guy:
I'm still a ways away from starting a build, but my mission includes light aerobatics, occasionally with a friend. While I'm just under 170#, some of my compatriots are around 220#. Playing with a few of the numbers you've listed, I just don't see how it'd be possible to stay within the aerobatics 84.5" aft CG limit if my empty CG comes out to anything above 80".
Does anyone know if the -14 suffers from a similar aft CG tendency? After a quick search I didn't see any discussion in the -14 forums about a similar topic, so I figured I'd address it here before starting something new over there.
Best,
Will
Note: I'm more concerned about Aerobatics CG comparison between the two. I know both the -7 and -14 will perform well for me during cross country flight.
Old 09-19-2017, 08:37 PM
Rbb469 Rbb469 is offline
80.9
Dues gladly paid!
Old 09-20-2017, 08:35 AM
Raymo's Avatar
Raymo Raymo is offline
I'm still a ways away from starting a build, but my mission includes light aerobatics, occasionally with a friend. While I'm just under 170#, some of my compatriots are around 220#. Playing with a few of the numbers you've listed, I just don't see how it'd be possible to stay within the aerobatics 84.5" aft CG limit if my empty CG comes out to anything above 80".[/i]
I ran the numbers on my -7A and could get to 1600 lbs with you, your compatriot and 18 gallons of fuel. You could take off with a little more fuel and calculate when you burned off enough to be under 1600.
I installed a 20 lb plate in front of my 3 blade Catto to keep CG such that it would allow 100 lbs of baggage. Using the above numbers of 170, 220 and 18 gallons:
CG is 79.55 empty; 83.96 on take-off and 84.11 after burning 10 gallons of fuel. Empty fuel with co/pilot is 84.24.
I had planned to swap the PC680 on the firewall for an EarthX to save 10+ lbs but will have to run the numbers to be sure I keep my CG about where it is.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 10-04-2017, 11:53 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Default 1123 Lbs
Left: 520,7 Lbs
Right: 521,6 Lbs
Tail: 80,7 Lbs
Total: 1123 Lbs
Engine: Aerosport power IO-375
Prop: Whrilwind 200RV
Avionics: Full Dynon package including 2 Dynon SV-1000T, AP with panel modules, VP-X Sport
Interior: Full Classic Aero Sportsman pakage
Its a bit on the heavy side, but OK considering that I have a big engine and a constant speed prop, a nice comfortable interior and superb avionics.
Just on the aft side of the enveloppe with max bagages, two pax and minimum fuel, as expected...
I'm happy...
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
