Old 02-02-2010, 11:13 AM
scard's Avatar
scard scard is offline
Originally Posted by David-aviator View Post
Go with a Barrett light weight IO360 and Catto prop and you'll never regret it.
That is exactly what I would do if I built another -9A.
Scott Card
RV-9A N4822C flying 1850+hrs. / Cedar Park, TX
Track
Old 02-02-2010, 02:06 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Originally Posted by R.P.Ping View Post
I have close to 500 hours on my 9. I have a 160 HP O-320 with a Hartzell constant speed prop. Weight and balance is right on and the plane performs wonderfully all the way to 17,500 ft. There is a huge difference between a 150HP and a 160HP and a HUGE difference in climb performance and comfort when cruising when using a CS prop. Also 1 gph less fuel consumption with a constant speed prop when in cruise. Donít worry about being light. If you can carry more because you have a little engine and composite prop you have no performance to carry the extra weight. My 2 cents.
Around here, we're constant speed prop fans too. We do live in mountain country with airport elevations beginning around 4000' msl. The constant speed allows for a brisker takeoff, quieter cruise flight, and excellent braking effect when getting back to the pattern. Lot's of RV's around here (including 9's), and C/S props are by far the majority.
L.Adamson --- RV6A/ Hartzell CS
Old 02-07-2010, 11:35 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Default There is a reason...
Originally Posted by L.Adamson View Post
Don't tell anybody.......... but his new replacement engine for the damaged 0-290 is a 180HP 0360. That's 20 HP over Van's recommendation for the RV9.
One time ... On Barnstormers ... There was a guy selling a 9 ... with a 200hp IO-360 ... would cruise at 225 mph ... Beyond Vne.
The folks at Van's design some really nice airplanes, and certainly had a good reason to restrict the 9 to 160HP.
Before you decide to beef up the engine ... Probably should read this "Why can't I use a larger engine?"
JMHO...
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 02-08-2010, 08:22 AM
airguy's Avatar
airguy airguy is offline
JMHO...
While you are certainly correct to be concerned about top speeds, flutter margins, and Vne in any aircraft, this is a PILOT problem, not an EQUIPMENT problem. It is the pilots primary duty to manipulate ALL controls in the aircraft (which includes power) to keep the aircraft within its flight envelope. If the pilot is incapable of acting as a pilot, then I still say he (or she) should stay on the ground, rather than trying to idiot-proof the airplane.
Know your limitations, and act within them.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-08-2010, 08:09 PM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Super-9 ??
I may get in trouble with the more conservative folks, but I would install an ECI IOX-340S (185hp and lightweight) and whirlwind 151 constant speed. I wouldnt even rule out raising the compression to 10/1 with electronic ignition. Just an observation but compairing VNE on the RV-4 vs. routine airspeeds from the HRII crowd it seems the safety margins for VNE are well.. generous. Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
Old 02-08-2010, 08:42 PM
Mel's Avatar
Mel Mel is offline
Also remember that the RV-4 was designed as an aerobatic aircraft. The RV-9 was NOT!
IMHO, the RV-9 and -10 were most likely not designed with limits as conservative as the aerobatic steeds.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 02-08-2010, 08:57 PM
N941WR's Avatar
N941WR N941WR is offline
I may get in trouble with the more conservative folks, but I would install an ECI IOX-340S (185hp and lightweight) and whirlwind 151 constant speed. I wouldnt even rule out raising the compression to 10/1 with electronic ignition. ...
Russ,
I looked at the IO-340 when picking the O-360 to replace the O-290-D2 in my -9. It turns out the O-360 puts out more HP, costs less, and only comes in a few pounds more. In fact, with a composite CS prop (Whirl Wind) it is still lighter than an O-320 w/ a FP metal prop.
I couldn't agree with you more Mel.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-09-2010, 08:35 AM
airguy's Avatar
Originally Posted by N941WR View Post
Russ,
Yep. My primary reason for choosing an IO360 vs the IO340S was that I want to be able to run Mogas, which means lower compression pistons, which rules out the 340. Current plan is an ECI IO360 with Whirlwind CS prop.
Garden City, TX
Old 02-09-2010, 02:40 PM
Finley Atherton Finley Atherton is offline
Just had this random thought someone may be able to answer.
The RV-9 can float excessively in the flare if the speed is a bit high or if the idle is set too high. Would the bigger 180 HP engine with its bigger FP prop be likely to increase the length of the flare all other things being equal? The bigger engine/prop would produce more thrust at idle rpm, but possibly offsetting this the bigger prop would present a larger surface area to the airstream and therefore give a bigger engine/prop braking effect.
Fin
9A
Old 02-09-2010, 04:16 PM
L.Adamson's Avatar
The larger engine with a fixed pitch prop on the 9, just won't help with any braking effect. The C/S will, and a 9 will actually fall through a flare.......just like my 6A, if you don't watch the airspeed. You wouldn't think a 9's wing would act like a heavier sink rate 6, but it does.....when combined with a C/S that can slow the plane down so fast.
L.Adamson ---- RV6A
