Old 06-17-2009, 05:08 PM
Bart Bart is offline
Default Stick grip hits panel
I've installed an Infinity Stick and find that the grip hits the panel in the full foward position. Have other folks had this happen? If so how did you remedy it? Do you need to if you are getting the Min/MAx travel on the flight controls?
Old 06-17-2009, 05:31 PM
Deems Davis Deems Davis is offline
Default 2 things that helped me
1. Initially I had the problem with the grip (CH/TOSTEN) hitting the panel even after they were cut down to min. I cut the verticalupright piece off fromn the curved portion, rotated the vertical aft 22 degrees to provide clearance, then had them Tig welded.
http://deemsrv10.com/43.5-controlsticks.htm
http://deemsrv10.com/album/Sec%2043....ork/index.html
2. Once I had all of the instruments and EFIS. installed in the panel with the panel in the plane I found that I had some interferrance wit hthe grips hitting one of the knobs on the EFIS. I remeasured the up/down travel and compared it to Van's spec and found that I had more than the plans called for in the down direction so I made a simple elevator stop out of some alum angle ind installed it.
http://deemsrv10.com/album/Final%20A.../DSC07196.html
http://deemsrv10.com/album/Final%20A.../DSC07199.html
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 06-17-2009, 06:07 PM
I also had this concern, best advice was to wait until the tail was mounted, and the elevator travel checked.
There seems to be a lot of excess travel without the entire assembly.
In addition, at least for the CH units, you can rotate them a bit, gives not only better clearance, but is actually more comfortable fit in your hand.
YMMV with the Infinity grips.
Old 06-17-2009, 06:50 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Some grips are a bit tall....... so shorten the stick a bit!
Old 06-17-2009, 06:58 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
When I changed to a different Ray Allen grip, I had to chop an additional few inches off. At least if you chop too much, a different grip can probably make up for it.
The bottom line, is that if you thumb rests on top of the stick for any controls, then the thumb should also miss everything on the panel. And this is assuming that flight surfaces are mounted and at their stops.
L.Adamson --- RV6A (flying)
Old 06-17-2009, 09:15 PM
rene@felker.com's Avatar
rene@felker.com rene@felker.com is offline
Here is a reference from the other list. I used Scott's method
View this previous thread.
http://forums.matronics.com/viewtopi...ght=stick+weld
Scott Schmidt
scottmschmidt@yahoo.com
Rene' Felker
N423CF RV-10 Flying
Old 06-17-2009, 09:51 PM
Webb's Avatar
Webb Webb is offline
Wait until you have the elevator installed. The stops in my 7 kept the stick from going all the way and hitting the panel.
Also, if you are in flight and push it that far forward, you better make sure you are securely belted in because you are going neg G's very quickly and looking directly at the ground.
Webb Willmott
Jackson, MS
N32WW
Old 03-20-2017, 07:49 AM
Bill Boyd's Avatar
Default No doubt I'm going to have this issue
and will have to cut/chop/extend something on each stick when the time comes. Right now the issue is trial-fitting the Infinity grips on the sticks - will need some sort of insert between stick tubing and the insert JD provides with the grips. 7/8" thick-wall aluminum tubing should work, with a little lathe work possibly needed. Do I want 2024T3 or 6061 for this?
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 03-20-2017, 09:22 AM
Ron B. Ron B. is offline
If I remember correctly he can also provide the correct bushings for your tubing size.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 03-20-2017, 09:40 AM
Super Moderator
Default Inserts
Spruce has them as well.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
