  #611
Old 02-01-2016, 06:38 PM
bhassel's Avatar
bhassel bhassel is offline
That looks great! I love those colors.
Bob
Bob Hassel
Santa Fe, NM
RV-12 - Kit SOLD!
RV-9 - Emp Completed - Back On The Front Burner - well maybe after...?
Glastar Kit #5500 on the way...the 500th produced
Subscription Paid for 2017
Home is where the hanger is...
Old 02-26-2017, 06:09 PM
madmaveric's Avatar
madmaveric madmaveric is offline
While waiting for the finish kit I brought a 3D printer and got a bit carried away at first printing epic world dominating monsters (albeit a couple of inches tall and made out of orange plastic ) but then looked at doing something for the aircraft that wasn't structural or hard for a first time CAD design.
I made a 57mm panel drilling guide, then a rivet pusher (to help push those rivets in the tighter holes) and finally a step plug (just the fronts, I have left the backs open to allow any moisture to get out).
3D part
Test fitting (one of the first ones I made that didn't fit very well)
And finally painted
*Apologies for the link in the photos, I linked them up from my blog site.
RV12 empennage, wings and fuse finished, finish kit now under construction.
Blog
Old 02-27-2017, 05:36 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Those caps look great! I wonder if they add a tiny bit of drag compared to when leaving the tubes open?
Chris, RV-12 HB-YSC
Final assembly
Facebook: http://www.facebook.com/magic.carpet.aviation
12-Town:http://12town.com/profile/Chris
=VAF= dues paid for 2018
Old 02-27-2017, 06:05 PM
maybe a bullet nose?
Old 02-28-2017, 04:26 AM
madmaveric's Avatar
I'm not sure how much drag will be introduced by these but I don't think there would be enough to cause issues.
For all I know I may have reduced overall drag, the drag from the larger surface area of the inside of the tube (plus the turbulence of the interruption where the tubes are welded) being removed vs the smaller surface area of the cap being directly into the wind (I doubt it would be an overall reduction in drag but it would mitigate it a bit :P)
A bullet nose would be more efficient than mine but I couldn't easily put the letters on it.
Alternatively I could remove the steps completely and carry one of these in the back for less weight and no drag .
Painted to match with the RV12 logo on it of course
Blog
Old 04-02-2017, 04:32 PM
Piper J3 Piper J3 is online now
Default Moving Day - Familiar Sight For Most Of Us…
I bought my 12 from original builder with 48TT. It’s an early kit SN120058. I bought the plane knowing most of the service bulletins hadn’t been completed. I flew the airplane for a full year and then brought the fuselage home this past November for upgrade and SB compliance.
So today the airplane heads back to the hanger with following upgrades/SB’s completed:
• Fuel tank attach modification
• Center section and side skin modifications
• Fuel tank slosh inspection
• Flaperon bearing bracket crack inspection
• Upper engine mount rivet replacement
• Inspect nose fork for cracks
• Inspect stabilator lateral bearing movement
• Oil tank mounting bracket addition
• Installed new U-00006D and U-00006A for front wheel fairing per SB12-08-09
• Installed new (8) stainless steel exhaust springs – Aircraft Spruce # 08-07632 GPL
• Installed Dynon D100 EFIS Dual Display
• Installed new main tires and air tubes
• (2) 500-5 6 PLY AWBS RETREAD,ELITE PREMIUM 2 GROOVE
• (2) 500-5 AERO CLASSIC **BUTYL** INNER TUBE TR-67 (GL-5067)
• Installed new Matco WHLBRL-1 - BRAKE RELINE KIT
• Cleaned and re-greased main wheel bearings
• Installed PTT switch on copilot control stick
• Installed split baggage floor and split rear bulkhead
• Installed Moeller mechanical float fuel gage in top of fuel tank
• Installed 5-pin Molex 61-405x2 connector for elevator trim tab servo in tail cone
• Recalibrated Dynon D180/D100 EFIS fuel quantity gage
• Installed new 5 Circuit Molex 0.062" male and female connector at elevator trim servo
• Bled air copilot left master brake cylinder
I chose not to install the fuel tank vent. I will keep the vented fuel cap because I use 93E10 auto fuel and want to minimize air exchange in the tank. This will help maintain fuel octane rating when airplane sits in the hanger. 5-year rubber hose replacement will be done at next annual condition inspection.
Airplane still needs to be weighed, CG calculated, installed equipment list, POH update, and make all appropriate logbook entries before flight. Last summer at KOSH I took the Rainbow Aviation Light Sport Repairman Workshop and have now attained my LSRM-A certificate.
Life is good…
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 333
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 04-03-2017, 05:36 AM
Neal Trombley Neal Trombley is offline
Smile
Life is good…
thats great.. good luck
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 05-22-2017, 10:31 PM
waterboy2110 waterboy2110 is offline
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
Old 02-02-2018, 12:29 PM
TanBerry TanBerry is offline
Question Looking for RV-12 or RV-10 builders near Phoenix
I have been thinking long and hard about starting on an RV-12 build. Anybody near the PHX area (I live near the SE suburbs) building an RV-12 or even an RV-10. Let me know if I can lend a hand in any way or may be even just to take a sneak peak. Basically looking to get inspired and make sure I can take on this adventure on my own in my garage (with some help from y'all).
Old 03-01-2018, 08:19 AM
Floresb18 Floresb18 is offline
Default First Status Update
Well don't know if I can officially call it a status but I ordered the empennage and fastener kit last weekend and received my builder number and also reserved my N number with the FAA. PROGRESS!! Cant wait to get the kit in to get started!!
I've created a builder log site through Weebly and will post as soon as I have some quality updates to add!
See yall soon
