  #1731
Old 11-22-2016, 05:39 PM
Louavul's Avatar
Louavul Louavul is offline
Default Milestone 2017
Having been building this aircraft for longer that I'd care to admit there was progress accomplished today.
Probably equal to "flipping the canoe" or being at peace with with the tip up canopy, the engine is installed.
I think I have found the tunnel and there is a faint light at the end.
Steven Hild
Rio Communities, NM USA
RV-7, FWF/Fiberglass, N590SC res
Contributing annually since January 2002
Old 12-29-2016, 09:32 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Gear on!
Whatís a builder to do while waiting for an A&P to answer his call for assistance in building his engine? Install the landing gear of course!
This wasnít as bad as I thought it was going to be. The hardest part was dead lifting/cleaning the front of the fuse high enough to have my son push the sawhorse under for support.
Iíve read here before that the powder coating might be an issue when installing the gears. This is still true.
You can see here where the powder coating on the left is marked up from the motor mount.
I had to remove 3/16Ē from the bottom portion of the left gear and 1/4Ē from the right to get the gears up for enough to align the bolt holes. Took a little time to remove the powder coating (didnít want to remove any gear metal) but it all worked out well.
Now waiting for my Lisle bearing packer so I can install the wheels and tires and have a rolling fuse!
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 01-05-2017, 11:06 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Default HS goes on
Last night I got my horizontal stabilizer drilled and attached to the fuselage. This is definitely one of those measure twice / cut once operations. My HS tips are within 1/16" measured to the same spot of the firewall. That took a lot of time and interrupting my spouse from catching up on Top Chef.
https://goo.gl/photos/gFuPtog9bkBqXun36
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
Old 02-28-2017, 09:03 AM
Chattin35 Chattin35 is offline
Initial engine start yesterday. Fired right up and ran well. No leaks! Only squawk was an inop EGT & CHT probe on the #3 cylinder (I probably swapped red wires on the EIS4000 harness -- should be an easy fix).
Getting closer to becoming an airplane .
Old 03-05-2017, 07:27 PM
Default She wants out...
Old 03-06-2017, 03:07 PM
longranger's Avatar
longranger longranger is offline
I like the paint scheme; I'm planning the same for mine...
Miles (VAF# 1238, Paid up as of 12/2016)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on order
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 03-16-2017, 04:08 PM
Default So, so, so close...
Down to the single digits of rivets left to pound... Can you tell I'm getting excited?
Old 04-22-2017, 03:28 PM
Simon Hitchen Simon Hitchen is offline
Default Final stages
The final piece to be painted.... getting ever closer to the move to the airport
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 05-17-2017, 02:36 AM
Almost ready to go the airport!
Simon Hitchen
FLYING!
Old 05-17-2017, 06:28 PM
Steve Melton Steve Melton is online now
I like it! A nice clean look.
