  #831
Old 02-13-2017, 05:27 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Not that I'd expect you would leave it on the ground for long, but that would be a good place for corrosion to start if the padding is at all moist.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 02-13-2017, 07:24 PM
goatflieg's Avatar
Absolutely. After the transfer it sat on furniture blankets for a short while before being placed on dry towels. The next day I made up the rug in the photo. Two days later it was placed on padded work stands, and tomorrow I'm fabricating a temporary rolling support for moving it about the shop by myself.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2018... extra payment included for psychological therapeutic services rendered.
_______________________
Old 02-14-2017, 10:55 AM
Waco01 Waco01 is offline
Default Bacon Finally At The Airport
Jason,
Glad to see that you are moving along, really looks great. I will have to stop by when I get a chance.
Val k.
RV-8
N81VK
Old 02-14-2017, 02:59 PM
jseavolt's Avatar
jseavolt jseavolt is offline
Happy to show it to you! The more eyes that look it over the better. I am so grateful for the help I get from other builders on this site as well as my friends at the airport(s). It really takes a village...
Things are really coming together quickly now, as most of the work was done at home. Still fabricating little things like a glove box, but it's pretty much final assembly at this point.
ps. Getting the aerolift off the truck and installed was quite the task. It has caused a little stir at the airport Everyone is shocked to see the Cub up on the ceiling.
Jason "Bacon" Seavolt
RV8 QB N143MS
6.5 yr build (1st flight 4/23/17)
-almost to 1st condition inspection!!..over 155 hrs in 1st 11mos of flight
Old 02-14-2017, 05:14 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Originally Posted by Boomer506 View Post
Very nerve wracking, but the first cuts and initial fitting seem to be going well. Will be even more nerve wracking when I start to drill into the darn thing.
Use SikaFlex, and you won't have to drill any holes! It's a much better system, overall and it looks fantastic too.
Bruce Swayze
RV-7A Standard Build
Working on Wiring and Panel!
Dues Proudly Paid for 2016
http://www.BrucesRV7A.com
Old 05-03-2017, 01:31 PM
bifft bifft is offline
Got my RV weighed today. 1002 pounds. Don't think its the lightest 8A ever, but not bad. Realized I need to measure the gear position in the level attitude (needed 3.5" blocks under the mains) do don't have accurate CG position yet. This is with paint, but no gear fairings or wheel pants. Helps make up for 261 lbs of me in it. Now just need to calibrate the fuel guages and time to call the DAR.
Equipment list:
O-360 with B&C starter
Christen inverted oil
Rotec TBI
Lithium battery
B&C SD-8 alternator
Catto 3-blade prop
Day VFR panel (no lights/no gyros)
Old 05-03-2017, 07:10 PM
nice and light. you'll get great performance. add the leg and wheel fairings and get another 13kts. love the paint.
Old 05-03-2017, 07:49 PM
Equipment list:
Rotec TBI
Lithium battery
B&C SD-8 alternator
Catto 3-blade prop
1002 # with 360 not bad at all. Perfect paint color for your landscape. I will be stomping your grounds in 5 weeks and want to make sure not to enter your "box"
Old 05-04-2017, 04:56 PM
snopercod's Avatar
Default Very impressive!
That's very impressive! You've got my fiberglass airplane beat by 30 lbs! Nice job.
(2018 dues paid)
Old 07-14-2017, 05:55 AM
jseavolt's Avatar
Default First Flight Video
A truly heartfelt thank you to everyone on VAF for all of the information and shared knowledge. I don't think that I would have embarked on such an enormous project without this community and resources.
I had first flight in April, but have been focused on test flying and all that goes along with frequent inspections/adjustments to the new airplane. I've got about 80 hrs on her now, started learning aerobatics, formation flying, and completed an IPC. All I can say to all of the current builders is to keep plugging away at it. The experience and plane has been even better than I had hoped it would be!
Here is my first attempt at making a video:
https://www.youtube.com/watch?v=WHT28sL0-58&authuser=0
RV8 QB N143MS
