Old 03-20-2017, 12:39 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Battery box question for these who have mounted engines
I am going to use a multi use battery box from earthx. This box will fit the earthx batteries and the traditional odyessy (if my weight and balance forces me to). This box is different from the kit one in that the mounting flanges bend outward rather than inward. Therefore it is a bit wider than the Vans box. Seeing what is on your firewall, would you recommend I mount it left or right of the intended location 1/2-1 inch mind you?
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 03-20-2017, 10:07 AM
n982sx n982sx is offline
The issue you will have with the standard location is on the outboard side. The standard battery box location has 1/4"+ distance from the flange of the brake fluid reservoir. Moving inboard to clear that should not be a problem.
Moving to the inboard side does bring you closer to the firewall pass thru but as long as you don't move very far it should not be an issue.
In my case, I have a secondary alternator from B&C that would be getting real close to the battery terminals if I had had to move the battery inboard.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 03-20-2017, 03:27 PM
Av8rRob's Avatar
Thanks Bob, any chance you could email me a picture of your situation as I too plan a b&c standby alternator?
Av8rrob@gmail.com
Rob Lasater
Paid dec 2017
