Old 03-18-2017, 12:08 PM
60av8tor 60av8tor is offline
Originally Posted by unitink72 View Post
I emailed Vans about this issue as I think it's a pretty big deficiency in the plans. They said its in section 5 (is that right?), but I don't recall seeing it. It gets most people, in my view it needs to be mentioned in section 6
It's definitely in there
Like some others, I was aware of it, ground off an amount to where I was beginning to worry about the flange material becoming too thin, and I still got some slight outies. Drove me nuts initially - thought I'd rebuild the VS at some point because of them. Several years later, I can't even notice them.
Jon
RV-7A purchased flying - Sold 6/16
RV-10 empennage delivered 1/22/14 (325JT)
Build: http://hhav8or.blogspot.com/
Old 03-19-2017, 03:11 PM
RandyAB RandyAB is offline
[quote=Several years later, I can't even notice them.[/QUOTE]
Thank Jon. Good to know!
Randy
Old 03-20-2017, 08:23 AM
tims88 tims88 is offline
I had a similar experience but I read and re-read (several times) the part in section 5 about this issue and I still ended up with small dimples. It makes me feel a little better knowing that so many others have the dimples too even though they knew they needed to shape the nose ribs some more.
PS - If you haven't dimpled the skins yet, be careful with the holes closest to the leading edge (these were the dimples I thought the thread was about when I saw the subject). I used the DRDT-2 with the male die on the bottom and ended up bending the skin a little around those holes. I think putting the male die on the top so that the skin wasn't flexed so much around the top of the DRDT may have prevented this.
Tim
Arvada, CO
RV-10 started 1/1/17
https://timsrv10blog.wordpress.com/
Old 03-20-2017, 12:04 PM
iwannarv iwannarv is offline
Does somebody have a photo showing the skin on and dimples showing for a visual?
Brad Brensing
RV-10 Tailcone
Old 03-20-2017, 09:24 PM
unitink72 unitink72 is offline
http://n67sc.blogspot.com/2016/12/ve...st-rivets.html
I didn't take a pic of the skin but there is one of the ribs.
Josh T
RV-10 #1750
N67SC reserved
2018 Dues Paid
Old 03-21-2017, 06:27 AM
A-Ron A-Ron is offline
Has anyone had the guts (or crazy enough) to give the protrusion a nice controlled whack with some something spherical to dent it in, then fill it with bondo or something like it? This crosses my mind daily when I look at my two protrusions.
ASEL Commercial/Instrument
N707XP Reserved
RV-10 Empennage- Complete
Wings- 99%
Fuselage-95%
Windows Done!
Working on windcreen
On it's Gear, Engine Hung, Prop On
Dues Paid
Old 03-21-2017, 08:00 AM
Default Uh, no
I'm guessing if you gave it a whack you would end up doing more damage than good...this is experimental, though, so if you give it a try make sure to post your results!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
