Old 03-16-2017, 04:51 PM
thoma015 thoma015 is offline
Default Fuel Sender Questions
Hi all,
I missed the part in the directions where it says "DO NOT" install the rubber gasket that came with the fuel sender unit. Well...i missed that and i did install the gasket and already covered it in proseal.
Has anyone else put the rubber gasket in there? Why the emphasis from vans to not include it?
-Hawk
Old 03-16-2017, 05:01 PM
Originally Posted by thoma015 View Post
Hi all,
The emphasis is because you're likely (not guaranteed) to get a leak.
I'd remove it, scrape off the proseal, and install the sender directly to the tank using proseal to seal it...
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 03-16-2017, 05:42 PM
Larco Larco is offline
This subject has been talked about over the years and this should help. Larry
http://www.vansairforce.com/communit...uel+gauge+leak
Old 03-16-2017, 06:10 PM
Mel's Avatar
Mel Mel is offline
Actually you may be OK with the rubber gasket. The cork one is the one that gives the most trouble. Over time the cork gets saturated and begins to leak.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-19-2017, 05:07 PM
Well I guess I'll peel off the proseal and discard the rubber gasket. Thanks everyone.
-Hawk
Old 03-19-2017, 08:15 PM
airguy's Avatar
airguy airguy is offline
Toss the cork for certain, and take a long look at the rubber one like a snake that hasn't bitten you yet.
A good thick layer of proseal can be broken up if you ever need to remove the access plate again, I've done it twice, just use one of the 6" stainless steel rulers like a knife and it works great.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 05-24-2017, 05:38 AM
cfish's Avatar
cfish cfish is offline
I just replaced the black rubber seal under the sender due to a very small leak.... it had deteriorated over 9 years and was installed originally using proseal on both sides. I have subsequently, after a few hours of goop removal, reinstalled the sending unit using only proseal (flamemaster cs3204) and no gasket.....
Craig Whiting
RV7 - Flying
Superior 180hp FP
VH-BZV
Caloundra
Australia
2017 Fees Paid
Old 05-24-2017, 06:04 AM
Jesse's Avatar
Jesse Jesse is offline
I usually do use the rubber gasket with no proseal. If it leaks a little, I tighten e screws until it stops. When that stops working, I will usually proseal around the edge.
352-427-0285
jesse@saintaviation.com
