Old 03-17-2017, 03:59 AM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by Mike S View Post
Yep--------used flox to marry the shape to the stab, then sanded the top to the thickness I wanted.
Flox is structural strength, you do not need cloth
Same here. Packing tape, flox, sand to shape.
Good thing flox it structural. I kid myself about my fairings not having any glass left after all the shape repair during construction.
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 03-17-2017, 05:27 AM
jimbower jimbower is offline
I did have luck with the judicious application of a heat gun. I don't think a hair dryer will get it hot enough. Take your time and bend it farther than you have to, and I think that bit will lay down. Last resort would be to cut a notch out of it and re-glass, but I don't think you will have to.
Jim Bower
RV-6A N143DJ
Flying since 2011
Old 03-17-2017, 05:47 AM
Follow Scott Hersha's suggestions. I do basically the same thing and it takes one to two hours a day for a week or so. I have not had a lot of luck with the heat gun as glass tends to have a bit of a memory. You can see fine examples of this memory at AirVenture when you look at nice painted farings that have gaps between the screws.
Try to make the part fit so that you can use the minimum number of screws. It looks better and you will get your time back many times over the years of maintenance.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 03-17-2017, 07:29 AM
snopercod's Avatar
Default post curing
I would try heat first. It's called "post curing" and I have read 80C for 3 hrs. is about right for vinyl ester resin. Disclaimer: You'll have to verify the proper time and temp yourself. I've always used a heat gun on small parts.
(2018 dues paid)
Old 03-17-2017, 08:55 AM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Default Thanks!
thanks for the replies. I stared at this for a while and figured I would ask the group since I was stuck. I will give the flox solution a try. How much of the fairing on the HS leading edge is needed? I've seen some posts where the fairing flanges are trimmed back. Is a .5" edge distance a good practice to follow?
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Old 03-17-2017, 09:37 PM
drone_pilot drone_pilot is offline
I had a similar problem and I made long longitudinal cuts (6" or so) down the fairing to relieve the tension that the clecos apply trying to pull the fairing down to the HS skin. That solved the puckering problem for me. I then laid a couple of plies of glass cloth over the cuts and sanded and it came out pretty nice. I hope that makes sense. The heat gun didn't work but the longitudinal cuts on the fairing between the VS and HS allowed things to twist and lay properly. The glass over the cuts locks things in place for a proper fit. I did lay packing tape down on all surfaces just because the epoxy seems to make it to places where you don't want it.
Ben
RV-7A Tip Up Airworthy on 12/20/2016
Pondering what I should build next!!!
Old 03-19-2017, 07:33 AM
Scott Hersha Scott Hersha is offline
Flox is structural - true, but keep in mind that if the magnitude of the 'pucker' is high enough, you'll have nothing but flox in places after grinding through the original layup from the top. I prefer to have a uniform layer of fiberglass cloth where it lays on the aluminum surface to tie everything together. Plus - it's very easy to do.
SH
RV-8
Cincinnati, OH/KHAO
Old 03-19-2017, 10:39 AM
gbitzer's Avatar
gbitzer gbitzer is offline
I was surprised by the fit of the stock Van's rear fairing. However it makes a great starting point. I simply wrapped the vertical and horizontal stabs with plastic film. (the type used for grocery bags works well, releases from the epoxy well). After protecting the stabs I glassed the stock fairing onto the plane and wrapped it around the front of the horizontal stab. The fit is great and the whole thing is held in place with 4 countersunk #8 screws. After 15 years and almost 2,000 hours it is still working great. Pics included.
don't wrap the glass around both ends of the stab unless you never want to remove it
Greg Bitzer
RV-6 / 180 CS
BE36 Bonanza
DragonFly Tug
Airwave Pulse Hang Glider
TeamRV
Stoney Point Field - 6GA0 Atlanta, GA
2017 VAF Dues Paid
Old 03-20-2017, 06:54 AM
Greg,
Beautiful job! I've done the same process a few times and it's not that difficult to do - just some time in sanding and waiting between lay ups/filling. Makes you look like an artist..... nice job.
SH
RV-8
Cincinnati, OH/KHAO
