Old 03-15-2017, 09:23 PM
goatflieg's Avatar
Default Flap/Aileron Trailing Edge Alignment: Good Enough?
Just did my first test fitting of my left flap on my QB wing, with the aileron in neutral position. Nailed the gap; exactly 1/4".. and the line up looks fairly straight overall with the forward hinge half clecoed in position. The trailing edge is very slightly displaced forward... looks to be .04" (1/25th of an inch). It is visually noticeable... but for a first try this looks pretty good to me. Just wanted to get some opinions before riveting. I could always do another hinge half and try to make it perfect... but the curve in each trailing edge doesn't even match to that kind of tolerance, so I'm thinking this is ok. What do you think?
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2018... extra payment included for psychological therapeutic services rendered.
_______________________
Old 03-16-2017, 02:46 AM
PCHunt PCHunt is offline
Hmmm, are you braggin', or are you complanin' ?
Looks like my standards are a bit too low, 'cuz that looks perfect to me!
Keep building!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2018 Donation Plus, Gladly Sent
Old 03-16-2017, 04:35 AM
Only you can make this decision. The fact that it bothers you enough to post it here makes me think that you will always know it's there. For the cost of a new hinge and a bit of time you can get this to point where you are satisfied.
Use the old hinge to lay out a few holes on the new hinge, where they "should" be. Then trial fit before drilling the rest. A long string pulled tight will help with the alignment, but at the end of the day it is what the eye sees that really matters. It will probably fly the same either way.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 03-16-2017, 05:45 AM
Default Good to go.
Just a little comment here. You may find that after you get up and flying you need to blunt or squeeze you tailing edges to take care of a heavy wing condition. You are more than good with what you have here only you will see it and it is only a distraction to your want to do a perfect job. I understand and complement you on that objective. If you have to do some adjusting after you get flying and most do. you will find your end radiuses changing this much are sometimes a little more. You have a nice tight hinge now, why drill it off and open those holes again for .04" when you may have to move it that much again anyway. You really do have a good thing going here "as Is". I used to judge aircraft at shows, this would not be anywhere close to a deduction only a well know and excepted look. Hope this helps, Yours, R.E.A. III #80888
Old 03-17-2017, 06:43 PM
Berchmans Berchmans is offline
Default Good Enough
I would say that's good enough and unlikely to have any impact on how the plane flys. If your worried about how it looks parked remember your flaps will always be down when parked.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2018
Old 03-17-2017, 07:54 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Not to mention, this is probably the only time in the life of your plane when these two will be in that exact position.
Do the other wing and see if you can do better, then decide!
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 03-18-2017, 10:40 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Better than most...
...move on to the next thing.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2018 Dues Paid
Old 03-18-2017, 02:47 PM
N1Flyer N1Flyer is offline
Know that better is the enemy of good! Looks great - go with it and ease up on being perfect or you'll never finish. Don't ask how I know:-)
