Old 03-17-2017, 02:04 PM
Mel's Avatar
Mel Mel is offline
Default No quite the first.
I was the first known participant in the program.
https://www.eaa.org/en/eaa/eaa-news-...-up-for-safety
I didn't bring anyone along until after the first 8 hours.
After that, I leaned on the knowledge of my peers for coming up to speed on the advanced functions of the G3X system like the GTN 650 and autopilot.
Your needs might be different. It is a GREAT program! As I recall, it is standard language in the OPLIMS (can someone confirm?) now. Your DAR might not have an option to include or exclude it. It is just a matter of your compliance with it... ie. aircraft equipment and pilot qualifications.
Have fun testing!
CJ
Actually, I issued an airworthiness certificate to an RV-9, N369RV, on October 4, 2014 with the inclusion of AC 91-116.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-17-2017, 07:18 PM
Triumph1974 Triumph1974 is offline
Default Good info
Thanks guys for the feedback on your experience with the program, and the glass cockpit comments (which is what i have...skyview). Looking forward to updating you all in a few months when we are ready to start testing.
I wonder if the Faa has published test stats on two pilot testing vs. the traditional approach.....or if there is enough data at this point to do a sampling.
So it does sound like the Dar needs to signs you off with the ac 90-116 then.....so need to find a DAR that is open to this appoach to
Flight testing phase 1.
Paul
Old 03-17-2017, 07:43 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Paul
Mel or Vic can confirm, but I think it is automatically included in the Ops Lims these days. It was when we did our Tundra about a year ago with the FSDO inspector - he was surprised when I pointed it out, because he didn't know about the APP.....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-17-2017, 08:11 PM
Mel's Avatar
Mel Mel is offline
Default Yes!
Paul
That paragraph is standard in all experimental amateur-built operating limitations issued since it became effective in October of 2014.
"Unless operating in accordance with AC 90-116, Additional Pilot Program for Phase I Flight Test, only the minimum crew necessary to fly the aircraft during normal operations may be on board. (36)"
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-17-2017, 08:13 PM
Originally Posted by Ed_Wischmeyer View Post
Along those lines, a statistic I've seen is that about a third of homebuilts involved in accidents these days have glass cockpits. And as an old user interface designer, and having worked my way up a hefty learning curve with little assistance, I can understand why.
One concept that needs to come to fruition is to have experimental avionics training available in the same way that experimental airframe training is available with an LODA. Hey, I can teach people to use a Garmin G3X touch system in my RV-9A and that will be valuable to them in whatever they fly, RV or not, even if they never touch the flight controls of the -9A. But as often happens, the rules haven't yet caught up with the new reality.
Meantime, I can give ground instruction on the G3X and not worry about insurance... hook up the ground power and roll the plane out of the hangar.
Ed
Yes, play with the EFIS incessantly and familiarize yourself with it on the ground. Also, declutter it as much as possible for the first flights...you can add more info later.
Doug
RV-9A "slider"
Flew to Osh in 2017!
Tail number N427DK
Donation made for 2018
Old 03-18-2017, 06:53 AM
Super Moderator
Watch for my column in the upcoming June issue of KP by yours truly on how to prepare yourself for distractions on first flights. Hopefully , you will find it of value, and certainly pertinent to this discussion.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 03-18-2017, 01:01 PM
Ironflight's Avatar
Vic
The picture alone is worth the price of the magazine!
Paul F. Dye
Old 03-20-2017, 04:37 PM
Captain_John's Avatar
Mel, I guess that you were the first UNKNOWN issuance then!
Lol
Seriously, I was wondering if I were really the first.
CJ
RV-7 Flying - 700 Hours in 3 Years!
Old 03-21-2017, 08:52 AM
jwilbur jwilbur is offline
... statistic I've seen is that about a third of homebuilts involved in accidents these days have glass cockpits. ..... Ed
Put another way, 2/3 have round gauges. This statistic alone suggests glass cockpits are better. .... But of course it's also true that 100% of people who ate pickles in 1865 (at the end of the American civil war) have died, so avoid eating pickles at all cost.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 03-21-2017, 10:22 AM
rmartingt's Avatar
rmartingt rmartingt is offline
That statistic alone is meaningless, just like the one that came out a while ago that said certified aircraft with glass have a higher accident rate. It's like saying "the majority of airplanes involved in crashes have propellers" and thereby concluding that propellers are a causative factor in those accidents. There are a bunch of other things that could be at play--type of aircraft and use of aircraft (VFR vs IFR) for instance--and what matters is if the accident cause has anything to do with the glass at all. Comparing the accident rates of high-performance airplanes flying actual IFR to steam-equipped day VFR trainers and fun flyers would be a red herring.
RV-7ER - fuselage structure in work
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
