Old 03-15-2017, 06:40 PM
Rob H Rob H is offline
Default Help, wing rivet question
RV12 Page 17-02 steps 4-7 , reference Figure 1
This is for newer RV12's and can be a retrofit for older models. When riveting the W1201A Doubler and bottom inboard wing skin to the wing spar and rib underneath, the most inboard rivet calls for CR3213-4-3. The problem occurs when I pull the rivet, it doesn't grab the flange of the wing rib underneath, the shop end pulls right through. It's happened twice now. I'm wondering if I can drill #40 a small piece of scrap to use like a washer underneath since it pulls right through the #30 hole in the rib flange? Has anyone else experienced this problem? Also, I'm guessing I can't use a LP4-3 because it's not the right spec for strength? Help please!
Old 03-15-2017, 09:36 PM
Jim T Jim T is offline
I just installed the retrofit kit on my older wings. Didn't have any problem with pull through. I'll take a closer look at it tomorrow to see how close I might have been to pull through.
Jim
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
Old 03-15-2017, 10:25 PM
Thanks, Jim. I didn't even know that mine pulled through until I turned the wing over to work on the ther side. After I installed another CR rivet, it looks like there isn't enough grip length on that rivet, whereas a lp4-3 would work fine. I put in an email to the Mothership.
RV12 emp finished
Wings in progress
ULS Fuselage kit - SOLD
iS Fuselage on order
Farmer
Vol FF
2017 Dues Paid
Old 03-16-2017, 09:43 AM
Rob.......please post what you hear back.
Thanks, Jim
Old 03-16-2017, 12:04 PM
If you are using the correct rivet, and the hole was not accidentally enlarged during removal of a previously installed rivet, The specified rivet should just barely fit through the hole so making a washer with a #40 hole should be of no benefit (the rivet fits a #30 not #40 hole).
Is it possible that when you final drilled the 8 holes for the BSPQ rivets you did the most inboard one also? If so, the Cherry rivet wont work.
Scott McDaniels
Hubbard, Oregon
Old 03-16-2017, 03:37 PM
Rob.......I just checked and mine are nice and tight. I looked at the shop head with a mirror and can see where they've expanded slightly.
As Scott mentioned........if the inboard hole was inadvertently drilled #22 like the other 8 that were called out for #22, that would account for the problem.
Jim
Old 03-16-2017, 03:52 PM
What are you using for a puller. Wasn't there some note that the puller Van's recommends won't work for certain rivets?
Bob Collins
St. Paul, MN.
RV-12iS fuselage
Builder log
Old 03-16-2017, 10:33 PM
Ok guys, I did not drill it out to #22. And Scott is correct that a #40 would not work. Van's email said it would be okay to use a CR rivet with a little bit longer grip length. So I'm going to try a 4-4 instead of the 4-3. I primed the doubler, skin, and rib, so maybe that added just enough thickness that the rivet wasn't getting a good grip. I appreciate the help and thanks for checking yours, Jim.
RV12 emp finished
Wings in progress
Farmer
Vol FF
2017 Dues Paid
Old 03-16-2017, 10:35 PM
I'm using a pneumatic puller from Cleaveland tools. I think by priming my parts, the grip length of the called out rivet wasn't quite sufficient.
RV12 emp finished
Wings in progress
Farmer
Vol FF
2017 Dues Paid
