Old 03-15-2017, 06:59 AM
bernsbm bernsbm is offline
Default Flap position indicator in an RV12
Confession... More than once I've been guilty of leaving my flaps down on takeoff while accelerating past 82 kts. I'd like to install a simple indicator on my Skyview display that would light up when flaps are down (similar to the canopy or spar pin indicators). I'd probably locate it near the RPM readout, as I check this several times on takeoff to confirm the engine is developing full power. Has anyone done this or something similar? Thanks in advance for any suggestions!
Barry
N12BB RV12 flying (~40 hours)
Mequon, WI
Old 03-15-2017, 07:07 AM
DaleB's Avatar
DaleB DaleB is offline
This is one reason I quit using flaps for takeoff. D180 here, sorry I can't help with the Skyview. A microswitch to tell you when the flaps are fully up would be pretty easy, but I don't know how to get that to display.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 03-15-2017, 09:13 AM
John-G John-G is offline
Barry-
I don't think adding a flap indicator will be all that hard. Section 7 of the Dynon SkyView System Instillation manual (version 14) shows how to do it ... in particular, page 7-72 shows an example of creating a contact sensor input. You will want to be creating a contact sensor .... much the same as the stall warning or canopy latch. If you look at the wiring diagrams the stall warning is wired to Pin 11 of the EMS module and the canopy latch is on Pin 12.
Pin 10 is vacant so that would be a good choice for adding your flap deployed warning indicator. Wiring would be done like the canopy micro switch where when the flap handle is moved, a ground is passed through the micro switch to pin 10 of the 37 pin WH-00020-1 ES-00057 female connector that plugs into the EMS module.
By performing the steps in section 7 of the SkyView Instillation manual to program pin 10, you will end up creating a configuration that can be saved as a .DFG file from the SkyView so you won't lose your settings moving forward. Below is a sample of that file that shows a NON-PROGRAMED Pin 10 along with the programmed Pins 11 and 12 (stall warning and canopy warning respectfully) for comparison.
Although I have not personally added any sensors to my RV-12 yet, this should help getting you moving in the right direction.
c37_p10={
valid=0
name=
id=
alarm_type=OFF
range={
max_display=30
min_display=0
range1_valid=1
range1_top=30
range1_bot=25
range1_name=R1
range1_color=RED
range2_valid=1
range2_top=25
range2_bot=20
range2_name=R2
range2_color=YELLOW
range3_valid=1
range3_top=20
range3_bot=10
range3_name=R3
range3_color=GREEN
range4_valid=1
range4_top=10
range4_bot=5
range4_name=R4
range4_color=YELLOW
range5_valid=1
range5_top=5
range5_bot=0
range5_name=R5
range5_color=RED
show_units=1
c37_p11={
valid=1
name=STALL
id=CONTACT
alarm_type=OFF
range={
max_display=30
min_display=0
range1_valid=0
range1_top=2
range1_bot=0
range1_name=PUSH
range1_color=RED
range2_valid=0
range2_top=5
range2_bot=2
range2_name=
range2_color=GREEN
range3_valid=0
range3_top=20
range3_bot=10
range3_name=R3
range3_color=BLACK
range4_valid=1
range4_top=5
range4_bot=2
range4_name=
range4_color=BLACK
range5_valid=1
range5_top=2
range5_bot=0
range5_name=PUSH
range5_color=RED
show_units=1
c37_p12={
valid=1
name=CANOPY
id=CONTACT
alarm_type=OFF
range={
max_display=5
min_display=0
range1_valid=1
range1_top=5
range1_bot=2.5
range1_name=OPEN
range1_color=RED
range2_valid=1
range2_top=2.5
range2_bot=0
range2_name=CLSD
range2_color=GREEN
range3_valid=0
range3_top=20
range3_bot=10
range3_name=R3
range3_color=GREEN
range4_valid=0
range4_top=10
range4_bot=5
range4_name=R4
range4_color=YELLOW
range5_valid=0
range5_top=5
range5_bot=0
range5_name=R5
range5_color=RED
show_units=1
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 03-15-2017, 10:48 AM
Do you have a switch installed to monitor the flap position? I installed one on my D-180 equipped RV-12. See picture HERE.
Joe Gores
RV-12 Flying
Old 03-15-2017, 11:14 AM
It would be nice if the D-180 was smart enough to see added flap switch and marry it to >80 knots airspeed to give both visual and audible warnings. Oh well, save money for eventual SkyView upgrade...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 333
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-15-2017, 11:23 AM
Mitch757 Mitch757 is online now
I also added a micro switch like Joe to the flaperon mixer arm and wired it to C37, pin 9. I added a flap "widget" and get "FLAPS OVERSPEED" now when I exceed 81 knots with the flaps not up. (Skyview Touch)
c37_p9={
valid=1
name=FLAPS
id=POSITION
alarm_type=OFF
range={
max_display=5
min_display=0
range1_valid=1
range1_top=5
range1_bot=2.5
range1_name=OFF
range1_color=YELLOW
range2_valid=1
range2_top=2.5
range2_bot=0
range2_name=ON
range2_color=BLACK
range3_valid=0
range3_top=20
range3_bot=10
range3_name=R3
range3_color=GREEN
range4_valid=0
range4_top=10
range4_bot=5
range4_name=R4
range4_color=YELLOW
Mitch
Old 03-15-2017, 06:08 PM
Oh, but it is. Well maybe not as smart as the SkyView, but there is a workaround. Since there is a big red spar warning light on the instrument panel, the spar alarm on the D-180 is redundant. Re-purpose the D-180 Spar alarm to serve as Flap alarm. See page 6-18 of the FlightDEK-D180 Installation Guide for setting contact alarms. Purchase an airspeed switch and wire it in series with a flap position limit switch. The flap switch should be closed when the flaps are down and the airspeed switch should be closed at airspeeds above 82 knots. The airspeed switch can be calibrated using a homemade manometer. The switch should be adjusted to close when 4.4 inches of water pressure (82 knots) is applied to the high port. See THIS picture of my D-180 with "flap" displayed.
Joe Gores
RV-12 Flying
Old 03-16-2017, 04:09 PM
RDupee RDupee is offline
I have been flying with an RV12 Flap overspeed alarm for over a year now, and still occasionally forget to raise the flaps.
I am away In China now, and cannot attach a photo, but I will post details of my setup when I get home.
Note that you do not have to add a "FLAPS" widget, but for setup, it is useful to add one to the 100% EMS screen only.
The audio message "Flaps Overspeed" is already available in the RV12 Skyview software.
Rich D
1980 Evans VP1 completed, sold.
1995 Avid Speedwing completed sold.
RV-12 120259 First flight July 2014.
RV-10 kit started Feb 2017.
Old 03-16-2017, 07:26 PM
Thanks everyone, exactly what I was looking for!
Barry
Old 03-24-2017, 01:37 AM
Default RV-12 Flap Over-speed Alarm
As promised before, here is some more info about my RV-12 installation
The Dynon SkyView gives an audible alarm (“Flaps Over-speed”) when the flaps are not fully up and the airspeed is over 82 knots.
A micro-switch is activated by the Flap Lever arm on the Aileron control bell-crank, which is below the pilots seat.
The micro-switch grounds EMS input “GP5” (in the manual as “Serial 5”).
This is connected to Pin 9 of the 37 pin connector on the EMS.
The operation of the switch can be checked by means of a “Flaps Widget” on the 100% size EMS screen.
Software changes from the standard SkyView version:
1. Setup Menu > EMS Setup > Sensor Input Mapping > Sensor Setup
EMS c37_p9 set to: POSITION POSITION FLAPS
2. Check that there is a line in the User Config dfg file:
“audio_sound_flaps_overspeed=SOUND_MODE_VOICE ”
3. Change Widget from “WIDGET_CONTACT” to “WIDGET_FLAPS”.
4. Setup Menu > HW Calibration > EMS Calibration> FLAPS Calibration
You can choose two calibration positions: Say 0 and 20 degrees
Rich D
