Old 03-15-2017, 04:35 PM
n233va n233va is offline
Both aircraft were flown out of Williams AZ this AM. Temps in the low 50's. No problems experienced. Both had fuel pumps running the other day. It is clearly a fuel blend problem. Winter blend in the states. Did not drain the tanks prior to takeoff and pressures remained steady.
Old 03-15-2017, 05:40 PM
AZLeeJay AZLeeJay is offline
Thanks for the info Bob, I think I'll add a little 100LL next time I add some gas. Do you know when they change to the summer blend here in Az?
Old 03-15-2017, 06:45 PM
cactusman cactusman is offline
May 1 is the final date for the refiners to switch and ship.
You might see it sooner.
I started topping off with 100LL whenever I can.
Burning 100LL will help with low fuel pressure warnings.
Old 03-15-2017, 08:05 PM
Boyd Birchler Boyd Birchler is offline
IF you can get it; summer blend (when it gets warm)91 octane auto "with out alcohol" is the best fuel for a Rotax. With alchol is next best. 100LL should be the last fuel of choice. Lead will cause problems with the starter clutch sprag, gear box, slipper clutch and in the Oil tank under the baffle. The engine is much happier without lead.
Old 03-15-2017, 08:21 PM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Rotax fuel
The Rotax engines DO NOT like 100LL. They are very different from other aircraft engines, 92 or better octane premium unleaded with no alcohol is the preferred fuel. If you need to run pure 100LL always treat it with a lead scavenger, TCP or Decalin. Also with 100LL the only engine oil allowed is Aeroshell Sport 4 plus, and with 100LL you need to change the oil every 25hrs. If you exclusively operate with 100LL the gear box needs to come off sooner, 600hrs instead of the normal 1200hrs. Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
Old 03-15-2017, 09:24 PM
I've never experienced vapor lock in the 5 years I've flown my 12 in AZ including airports like Sedona and Valle and Williams in high country. What I have experienced is slight roughness when I pull back the throttle to descend and land. My engine has also developed a habit of starting and dying once before a second successful start. Full power and cruise are smooth as silk. I suspect a dirty idle jet, and I cleaned the carburetors during my ongoing annual. When I finally finish the annual it will be interesting to see if the issue is solved. If not, I guess I'll bite the bullet and pay to have a ROTAX shop overhaul them.
Rich
Old 03-16-2017, 06:51 AM
It’s not the seasonal vapor pressure blend of the auto fuel, but rather the residual heat after engine shutdown that causes the fuel to boil off in the carburetor float bowls as I described in my post #10. Using 100LL doesn’t fix the problem.
The RV-12 has a tightly cowled engine and when you shut it down the heat remains for a long period. If the engine cools and you restart at a later time – no problems. Cool fuel and cool carburetor bodies allow fuel flow with no harmful vaporization. Engine starts and you’re on your way.
What you have to watch out for is restarting a warm engine that has sat for some time. In this case there is likelihood that fuel has vaporized from the float bowls and the carburetor bodies are still warm. That is why it is best practice to allow the electric fuel pump to operate for approx. 5 minutes to recirculate cool fuel through the upper distribution manifold and return to the fuel tank.
I experienced this phenomenon just like others have. I was hoping rides with frequent start/stop and had the engine stumble on several occasions. I follow the hot-restart rule now and haven’t had a problem. I run 93E10 auto fuel as recommended by Rotax. 100LL as mentioned in above post is undesirable in the 912 because lead spins out and deposits in the gearbox and also presents as sludge in the oil tank.
The only concern running unleaded auto fuel is the octane rating can be reduced if stored improperly or for long period of time. I use fresh fuel and fly often. I have an early model 12 and elected not to install the fuel tank vent. I stayed with the vented fuel cap which minimizes air transfer in the fuel tank when the plane is stored.
I didn’t mean to write a book on this subject – just trying to keep us safe…
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 350
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-16-2017, 07:03 AM
David-aviator David-aviator is offline
When I was flying with Subaru engines and mogas, I tested fuel before take off with the Hodges vapor tester, found winter blend way below safe flight reading one time and drained fuel.
At that time the Hodges tester was sold by Petersen with the mogas STC kits for various engines.
I found that ethanol eventually destroyed the tester, it had plastic tube. I called Petersen about it and he said he would consider having it made with glass tube but I don't think anything came of it. In fact I believe he stopped selling the tester, maybe because of liability issues.
I've considered running 91 octane mogas with the Superior IO360 180 HP engine but when I could not find another Hodges tester, it was factor to stick with 100LL. The other of course is the engine driven fuel pump, its internal materials probably are ethanol ok, like the AFP system, but manufacturers of fuel pump will not verify it.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2018 This place is worth it!
Old 03-16-2017, 07:31 AM
Tomcat RV4 Tomcat RV4 is offline
Sounds like another good reason to use Subaru with factory fuel injection controlled by
SDS FUEL/IGNITION CONTROL !
Tomcat RV4
dues paid and worth every penny
Life is uncertain -Eat desert first !
Old 03-16-2017, 07:36 AM
DonFromTX's Avatar
IF using Decalin or TCP, does that mean you can change oil at non leaded intervals, and none of the bad things from lead will happen to your engine?
Retired US Army Officer
