Old 03-14-2017, 12:10 PM
asw20c asw20c is offline
Default Elevator Trim Motor
When I installed the elevator trim motor the actuator arm appeared to be at one end of its travel, which means that the trim tab is fully extended in one direction. I'd prefer to have it positioned "in trail" so there is less chance it can get damaged during the build. I assume it would be a simple matter to hook it to a battery, but I don't know which pins, polarity, or voltage to use. Anyone have some insight? Is this as easy as a 9v battery and a jumper wire?
Empennage Complete Except for Tips
Wings Underway
Old 03-14-2017, 12:47 PM
N804RV's Avatar
N804RV N804RV is offline
Yes!
If its the Ray Allen servo, they are 12vdc. But, 9vdc battery will be sufficient to power it on the bench.
The wiring diagram should have been in your kit. If not, go to:
http://www.rayallencompany.com/RACme...onsT2andT3.pdf
On the servos I'm familiar with, (please do your own homework) the 2 white wires are connect to source and ground via a rocker switch. The switch position determines polarity of the 2 wires based on whether you want it to extend or retract.
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 03-14-2017, 01:02 PM
Mudfly Mudfly is offline
Yes. Just use a 9v "smoke alarm" battery and jumper wires to white wires.
Reverse polarity to change direction.
It's a small step, but fun to see the first moving part of your RV
Shawn Edwards
RV-14A (140174)
Empennage purchased (pre-owned) August 2015
www.myrv14build.blogspot.com
