Old 03-14-2017, 02:44 AM
Pin 21 Pin 21 is offline
Default Tail Wheel Weight
Can anybody tell me what their aircraft weighed on the tailwheel in the 3 point position ? I did a rough check on mine on the weekend in the 3 point position and it looks like I might have a big problem
Old 03-14-2017, 04:46 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Don't know why you would weigh it in the 3-point position, but mine weighs 75 pounds in the level position if that helps.
Ron Schreck
IAC Director and National Judge
RV-8, "Miss Izzy", 2100+ RV Hours
Track Me
VAF 2018 Donor
"He who demands everything that his aircraft can give him is a pilot; he that demands one iota more is a fool."
Old 03-14-2017, 05:52 AM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
73 on mine
Update: Catto 3 blade prop
Dan "RoadRunner" Landry
Morphed RV7, N20DL, PNP Pilot
1050+ hours, hit 1000 enroute to Oshkosh
2017 Donation Paid
Old 03-14-2017, 06:15 AM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Mine weights about 70 level. Don't know exactly in the 3 point position but do know it is quite a bit more. Why do you think you have a problem?
RV-7 Tipup, Flying, I0-360,
Hartzell, Dual Skyview
Old 03-14-2017, 07:05 AM
n816kc n816kc is offline
Default RV-6
weighed in at 54# in level attitude.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2018 =VAF= donor
Old 03-14-2017, 09:57 AM
grubbat's Avatar
grubbat grubbat is offline
Default Avg weight
There is a sticky where lots of folks have posted their tailwheel weights. Seems like most are in the 70's. With CS prop and empty weight, mine is 56#. With Catto prop and full fuel, it goes up to 74#. Mine is a -9 so will differ some.
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1967 Twin Comanche C/R, Flying......
Old 03-14-2017, 01:51 PM
I did a quick check without jacking the aircraft and the tailwheel weight is approx 115 lb in the 3 point attitude,that is the reason I asked if anybody knew the weight in that position, I have seen the sticky with tailwheel weights in the level attitude and I have started to panic
Old 03-14-2017, 01:59 PM
grubbat's Avatar
Default level and reweight
Level plane then reweight just the tailwheel. I bet it comes back to the 70's.
Craig
RV-3 Sold
RV-6a Sold
Old 03-14-2017, 02:16 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
RV-8 with 64 lbs on the tailwheel in level condition. Battery on firewall.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 03-14-2017, 02:23 PM
brad walton brad walton is offline
RV8 w 66 lbs in level stance. IO360 w Catto 3 blade
