Old 03-10-2017, 10:44 AM
DanH's Avatar
DanH DanH is offline
Default Circuit Board Mounting
A best practices question please...
I want to mount this circuit board in this box:
I can machine hard mounting points, or some other elaborate mounting solution. However, is it permissible to simply place four blobs of an "electronics safe" silicone RTV in the bottom of the box, then float the board on it?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-10-2017, 10:49 AM
Lars Lars is offline
What loading will the device be subject to?
My default inclination is to say yes, just use the silicone...
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
500 hours as of September 30, 2017
Old 03-10-2017, 11:04 AM
DaleB's Avatar
DaleB DaleB is offline
RTV or hot melt, if it's an indoor thing. The fancy way would be to remove the existing mounting bosses, then drill and use nylon standoffs and screws. Depends on the environment in which it will live.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 03-10-2017, 11:07 AM
wirejock's Avatar
wirejock wirejock is offline
Default Stand off
Agreed. Local hardware stores usually have Delrin or Nylon stand offs. Usually a star washer is installed on the top of the board before the nut.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-10-2017, 11:09 AM
Ralph Inkster Ralph Inkster is offline
Don't know about 'best practices', but how about 5min epoxy (or JB Weld) 4 studs to the box? Insures ability to service later.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 03-10-2017, 11:22 AM
Weasel's Avatar
Weasel Weasel is offline
Not sure on your time frame. If you draw an adapter in cad shoot me the STL file and I will print the adapter for you or if you want draw up the entire box with mount points like you want and I will print it.
No charge. I already owe you for your many contributions
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1300hr counting
Fisher Classic Cassler Power VW sold
RV-8 700+hrs
Carbon Cub 180 hr
One-Off Super Cub 90 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 03-10-2017, 11:30 AM
az_gila's Avatar
az_gila az_gila is online now
Thumbs up Normal practice
If it was mine, I would "Dremel off" the existing molded in attach points and drill holes in the base to match the mounting holes in the circuit board.
Countersunk screws and the previously mentioned nylon spacers from the Ace Hardware aircraft aisle finish the job off.
It probably would take less time than reading VAF for the day...
PS, is it a flap/cowl flap position indicator?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-10-2017, 12:19 PM
Jordan1976 Jordan1976 is offline
Silicone and other adhesives are used to mount and stabilize electronics all the time. Most cell phones today are stuck together with adhesives, not screwed together. One of the ways to make something as environmentally robust as possible is to just bury it in epoxy or silicone. Silicone is nice because it has a bit of give and vibration damping. The only real downsides to these options are maintenance.
Do whatever is fastest.
DanH's Avatar
Thanks gents.
Voltage monitor, with a built in display and settable upper and lower limits in 0.1V increments. The blue relay can operate whatever, here a panel mounted LED under the #2 ignition switch. I'll set the low limit at 13V, so the LED will come on prior to start, just like an alternator light. The idea is to keep an eye on the diode-isolated #2 battery charging for the EI.
My 2010 vintage GRT Sport monitors its own power inputs, but doesn't have an available input to alarm an independent bus voltage. I suspect some EFIS units can do it. Seems like a useful feature as the world moves toward more EI and EFI usage.
Not too worried about maintenance. You're looking at a whopping $7.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-10-2017, 02:40 PM
rapid_ascent rapid_ascent is offline
I would go with Gil's idea.
It looks like the mounting holes would interfere with the existing molded standoffs. Cut/grind those off with your dremel then use some 0.25" standoffs to mount the board. You'll probably have to use a nut on the top of the screw unless there is enough height in the box to use longer standoffs. If you can fit longer standoffs then I would use threaded standoffs and a screw through the back of the box and a screw through the circuit board mounting holes. Use locktite on the screws.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
