Old 03-09-2017, 09:36 PM
Default Bonehead move on compression test
I'm doing the 5 year rubber replacement, so I have a lot of stuff removed to gain access to hoses. That includes the oil tank. Yesterday I decided to do the compression test with the oil tank hoses disconnected. Bad decision! Blew oil all over the place! Pretty good lesson on the effectiveness of piston ring blow by as opposed to a scavenger pump!
Old 03-10-2017, 11:20 AM
Jetguy's Avatar
Jetguy Jetguy is offline
What No Pictures?
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Jetguy@att.net
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 03-10-2017, 03:14 PM
Are you cranking the engine or using differential-pressure tester?
DP is much safer and allows better diagnostics to determine if leakage is ring or valve related...
Hinckley, Ohio
P/ASEL 1970 Sport Pilot since '04
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 03-11-2017, 11:26 AM
I use the DP method. The oil blew out the return line as soon as I applied air pressure to the cylinder.
Old 03-11-2017, 08:18 PM
R100RS R100RS is offline
Yes, with the DP method, a loud gurgling (as occurs when the 912 engine is "burped") is audible when the cylinder is pressurized (just remove the oil tank cap to hear it quite clearly).
