Old 03-09-2017, 06:23 AM
caapt caapt is offline
Default Tires for grass
Has anyone used wider tires for grass fields?
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Old 03-09-2017, 08:12 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
No wider tires here but my 9A lives on grass. At least one takeoff and landing has occurred on grass for just about every flight it has ever flown. The only modification I have made to the landing gear is to install the Anti Splat nose gear stiffener. Otherwise everything is stock. Including the stock main and nose tires. I believe any alteration in tire size would require other escalating modifications to other components of the landing gear.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 03-09-2017, 04:28 PM
rodeja rodeja is offline
Stock tires and wheelpants and lives on grass. Wheelpants may come off in winter depending on how bare and wet the RWY is.
Ron J
RV9 - Bought
160 HP 0-320
#90899
C-FTJE
Old 03-09-2017, 05:28 PM
Ron B. Ron B. is offline
My grass strip is way too soft this time of year. No problem for the bushwheels on my SuperCub but my RV-14A leaves ruts and I would think it would be dangerous to use. I'm thinking of looking into an alternative wheel to install so I can use my RV-14A in the softer months.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 03-09-2017, 06:28 PM
scsmith scsmith is offline
Sorry I don't know what the standard tire size is for the -14. But for my RV-8, the larger 380-150-5 are absolutely fantastic on grass. Standard wheel pants fit, mounted 3/4" or so higher than standard, and a blister bulge on the inside to help clear the brake caliper. I would absolutely recommend these to anyone that operates on grass, gravel, sand, dirt.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 490 in 8-1/2 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 03-09-2017, 09:42 PM
Bevan Bevan is offline
I like my 380-150-5 for the mains on my 7A. 500x5 on the nose with a Grove 3 piece axle. What's not to like? Handles great!
Bevan
RV7A Flying!
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
