Old 03-08-2017, 03:50 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Question Step Support Block
What am I missing here? Step 1 calls for drilling the holes in the blocks with a #10 bit, but the holes in the ribs for the bolts (AN3) are #12. Why the (slightly) larger holes in the blocks, especially if you're using them for guides to match drill the #12s in the ribs?
Thanks.
Jeff
Jeff Rich
RV-10 empennage done for now. Wings done for now. Working on the (SB) fuse (Section 43: Cabin Cover)
Finishing Kit is here! Check for the motor cleared
N313KC reserved
In the garage for now, KJVY this summer
Old 03-08-2017, 03:59 PM
SeanB's Avatar
SeanB SeanB is offline
Default material difference
Hi Jeff,
It's been a long time ago for me, but I believe when you drill the blocks, the holes shrink a little once you remove the bit. Probably due to the material type (UHMW or Delrin???). I think you'll find the #12 bit you use to match drill into the aluminum will have a snug fit when you pass it through the #10 holes in the blocks. Maybe confirm this theory if you have a piece of scrap. There are other areas I believe the same #10 technique is used. Check flap arm mounting blocks, rudder pedal blocks, etc.
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2017 VAF SUPPORTER
Old 03-08-2017, 04:13 PM
Default Yep!
Sean,
You're quite correct. Just got off the phone with Gus at Vans. (I usually forget that service is even available b/c their hours and mine usually don't coincide.) But that's exactly what he said.
Thanks!
Jeff
Jeff Rich
N313KC reserved
