Old 03-07-2017, 02:38 PM
Default RV14 Canopy removal
I am going to be finishing off the canopy a couple of days and wondered if the flying guys can answer a question I have regarding the canopy. There are little covers that go over the canopy hinges. Is it possible to remove the canopy with those covers in place?
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 03-07-2017, 04:12 PM
Aussieflyer Aussieflyer is offline
Default No Luck
I tried removing the canopy leaving the hinge covers on. No luck, they got damaged. Luckily I got sufficient materials in the kit to build spares. Suggest everyone build the spares, paint them and wait for a rainy day when you might need them. I don't plan removing my canopy again.
Old 03-07-2017, 04:14 PM
TimO TimO is offline
They will definitely get ruined if you do not remove them before removing the canopy. Then again, if you do remove them, there's probably a >90% chance that you'll ruin them too, so like the other poster said, you may want to make multiples and have them on hand, and paint them to match as well.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1300+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 175+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 03-07-2017, 04:15 PM
Yes, but it will destroy the covers.
They are intended to pop away when the canopy jettisons.
If you don't want them damaged, you need to insert a small pin in the lock release hole, push down very slightly and then slide the cover aft.
Scott McDaniels
Hubbard, Oregon
Old 03-07-2017, 07:52 PM
Thanks all, I am going to think about this one. It would be nice to have them easily removeable.
CPL & IFR rated
Fairlea Field
