Old 03-07-2017, 09:55 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default RV-9A cg
Just put together a spreadsheet for my -9A, with the cg expressed in % MAC. I suspect I've got an error somewhere, because as long as the weights are within bounds (75 lb baggage), the spreadsheet says that I can't load the plane out of the "utility category" envelope.
Do I need to keep looking for an error in the spreadsheet, or is the cg envelope really that usable?
Ed
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual screen G3X with autopilot, GTN 650)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2018 dues paid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 03-07-2017, 10:06 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
That sounds about right, at least for my -9. I used a 4# crush plate which allows me to carry 100# in baggage area and still be within c.g. in almost any realistic configuration, but I suspect if I would have been willing to give up that extra 25# of baggage I could have done it without the crush plate.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 03-07-2017, 12:37 PM
bruceh's Avatar
bruceh bruceh is offline
I gave myself an extra 50 pounds of gross weight and I can't realistically get it out of balance unless the pilot weighs nothing, with minimum fuel and full baggage (100 pounds).
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 03-07-2017, 12:58 PM
YellowJacket RV9 YellowJacket RV9 is offline
I can't find any realistic way to get out of CG either, as long as I am in the plane - I can take up to 100lbs baggage. I have an O-320 at metal Sensi FP prop.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 03-07-2017, 01:05 PM
krw5927 krw5927 is offline
This is what I found as well. It's not necessarily a mistake in your numbers. For my plane, as long as there's a pilot (even a young kid) and enough gas to get off the ground, I can load out the remainder of the gross weight any way I want and not worry about CG being out of the envelope. Yours may vary of course, but what you're finding isn't uncommon.
Kurt W.
RV9A
FLYING!!!
Old 03-07-2017, 07:45 PM
Thanks, all!
Ed
2018 dues paid
Old 03-08-2017, 05:13 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Wide range
Similar results on my 9A, FP, IO-320.
I used a spreadsheet to calculate W&B for numerous scenarios prior to DAR visit:
- Couldn't exceed aft C.G even with bingo fuel and aircraft at 1,750 gross with pilots and baggage (I placarded for 100# limit).
- Light pilot solo and low fuel would be enough to exceed forward C.G limit.
- Flown solo and full fuel needs a few pounds in baggage area to prevent exceeding the nose wheel limit.
Love my RV!
Alan
RV-9A N984AW
Old 03-09-2017, 07:12 PM
What's the nosewheel limit? I missed that along the way.
Thanks!
Ed
2018 dues paid
Old 03-09-2017, 08:47 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default Nose Wheel Weight Limits
Thanks!
Ed
Check out the Nose Wheel Weight Charts in Appendix A of this SL (last page for the RV-9A):
https://www.vansaircraft.com/pdf/Nos...ice_letter.pdf
"Appendix A of this Service Letter contains charts that allow a pilot/operator to estimate the weight on the nose gear given the CG and aircraft gross weight. Operation within these limits is highly recommended and will provide a greater margin of safety should “mechanical factors and/or pilot technique” add to the normal, gravity induced load on the nose gear."
Carl N.
Arlington, WA (KAWO)
RV-8, 320 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 03-13-2017, 05:41 AM
Robert M's Avatar
Robert M Robert M is offline
Default re: RV-9A cg
While we are on the subject of W & B, I was curious, has anyone ever PUT 100 lbs. of weight in the back of an RV-9 or -9A?
And as always, thanks for the replies.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
100% finished - FLYING
Mosquito XEL kit in garage waiting to be built.
