Old 03-15-2017, 04:53 AM
Pittsartist Pittsartist is offline
Hi Bob,
The gussets are from drawings often referred to as the "Netherthorpe mod" here in England. It's an LAA "Repeat mod" first done on G-ODEE in 2004. It seems almost every UK aircraft I look at has had this done
They are basically home made from 1/8" 4130 Steel plate, 4 parts are added - the elongated triangles (welded top & bottom) and the roughly 2 x 2" end plates welded to the mount ends.
Richard
Old 03-15-2017, 08:48 AM
FLY6 FLY6 is offline
Default Cowl
Have you put the cowl on yet? From the picture it looks as if there is an area that is going to be close to the cowl at the landing gear.
Al Grant
Flying RV6, O-320
Stoney Creek, On
Dues Paid
Old 03-15-2017, 08:51 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Richard,
Thanks for the reply.
1/8 is thicker than the Van's gussets.
12 years of history says something!
All good info. Best pictures I have seen posted regarding the fix.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 03-16-2017, 05:09 AM
Yes - all fits ok with no mods to the cowl (Phew !)
Old 03-20-2017, 05:30 PM
RV6_flyer's Avatar
Originally Posted by RV6_flyer View Post
The cracking is very common for high time RV-6s and RV-6s that operate off of grass. The fix is to install the WD-762A-L and WD-762A-R Gear Socket Gusset to engine mount that is used on the RV-7.
At 2,724 hobbs hours, I added the gussets to my mount.
Here is what the gusset looks like on my spare engine mount.
Welding done by a professional Aerospace welder.
Here is a video clip of one of the gussets.
https://youtu.be/7MBCb1X-Z2c
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 03-21-2017, 06:03 AM
Bob Martin's Avatar
Default Nice example
Gary,
Nice work, good example of the repair.
Thanks for pictures.
Of all my spare parts...I never thought to keep a "spare" engine mount!
Bob Martin
Old 03-21-2017, 07:06 AM
rvsxer rvsxer is offline
I just found the same crack, on the right side on my RV-6 after 1450 hours. The left side cracked and was repaired a few years ago. This time the mount came off for the gusset mod, and it's over at Aerospace Welding in Eagan, MN for the full treatment. One less thing to worry about later.
Mike Hilger
RV-6 N207AM w/G3X, 1,400 hours +
South St. Paul, MN (KSGS)
Senior Tech - Panel Design, SteinAir, Inc.
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 03-21-2017, 05:30 PM
N941WR's Avatar
N941WR N941WR is offline
OK, you have me frightened now. My -9, mount vintage 2009, doesn't have those additional horizontal braces.
I guess I'll be taking a closer look at my lower mounts the next time the cowling comes off.
Thanks for the great write-up!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-21-2017, 06:30 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Here is what the gusset looks like on my spare engine mount.... Welding done by a professional Aerospace welder.
Gary, after all that welding on the gear sockets, do the gear legs still slide into the holes?
Heinrich
Old 03-21-2017, 09:05 PM
RV6_flyer's Avatar
Heinrich
Yes. TIG welding does not appear to make as much heat or at least there was no issue.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
