Old 03-06-2017, 10:42 PM
dave4754's Avatar
dave4754 dave4754 is offline
Default Looking for any help on Ground adjustable Sesenich
Hello All:
I am posting to ask anyone who has installed the new Ground adjustable Sensenich prop on their RV 7.
I talked with Vans today and they couldnt help much as they havent put one on as yet. Has anyone one here installed one on their RV7?
How did you overcome the weight problem being too light that is?
Has it been prone to rock chips?
How did it match to the cowl?Did you need a special crush plate.
oh yes i checked the Search engine on here and have been monitoring this subject for the last year so any with experience i would love to hear from you.
DAve
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 03-07-2017, 12:23 AM
bruceh's Avatar
bruceh bruceh is offline
I have the version for the IO-320 on my RV-9A. The light weight is good for the balance. The -9A has a lighter weight restriction on the nose wheel. It comes with the spacer and just bolts right up to the crank. No special or additional plates required.
I have had several chips taken out on the back side that I have had to repair with some epoxy and cabosil. Easy to fix, but it has happened more than I would have hoped for. The front side is still immaculate and the metal edge is in great shape.
Before:
After:
Another issue that I had to fix was that the gel coat on the carbon fiber spinner bulkhead was rubbing on the rough inner surface of the spinner itself.
White powder is gel coat dust.
I fixed this by putting some thin UHMW tape segments on the edge of the spinner bulkhead. Hard to see in the picture below, since the tape is clear, but it has held up well and no more rubbing.
I've had the prop on and off several times (to fix a leaky crankshaft seal). The special Nord-Lock washers are good for a couple of cycles, but I did buy some replacements at the last go around and they aren't cheap. The prop adjustment is straightforward with the various width pins they provide. I've had it set to #4 and to #5 (current position). Not much difference in top speed. Performance is outstanding.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
