Old 03-06-2017, 08:34 PM
mizer2167 mizer2167 is offline
Default Is it possible to convert a 9a to a 9 and vice versa?
I was wondering if it were possible to convert from conventional gear to nose gear on a -9?
If so, is it an involved or difficult process?
Old 03-06-2017, 08:56 PM
Anything is possible. I bought my fuselage set up for conventional gear and I changed it to nose gear. It wasn't that big of a deal but the plane wasnt finished. The wing mount bolts are a PAIN with the gear mounts being in the way, but it is possible to make it work.
Vans has a kit all set up for you to purchase. Basically it is new motor mount, gear, and wing bolts. The steps are a pain because you have to drill out the floor panels to fit them. There are a couple holes from the conventional gear that you will have to deal with, but not a big deal.
One decision you will need to make is if you want to take the rear gear bracket out. I didn't. It adds a pound or two to the far back, but it looked like too much trouble to take it out. I have thoughts of putting a small wheel back there just to make people wonder!
Have fun and get the plane you want - not what anyone else thinks is best.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 03-07-2017, 05:02 AM
bret's Avatar
bret bret is offline
A 9 driver did this up in Stead Reno....forget his name.......
2018 gladly supported
Old 03-07-2017, 06:07 AM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Yes. I converted my 7A to a 7.
Essentially the same.
You need to buy, new engine mount, gear legs, tw mount & assembly.
Others will buy up your old engine mount, nose gear & gear legs.
The conversion is not difficult except removing the old gear weldments, if you have fuel lines & wiring running through them. Also, the cowling may need adjustments as the engine may not seat exactly as before.
I'm based at KCLW if you'd like to get together to discuss it. Send me a PM.
Also, search the archives as there's been plenty of discussions on the topic.
Dan "RoadRunner" Landry
Morphed RV7, N20DL, PNP Pilot
1050+ hours, hit 1000 enroute to Oshkosh
2017 Donation Paid
Old 03-07-2017, 07:10 AM
N941WR's Avatar
N941WR N941WR is offline
While you can do it, it is not like a Sportsman or Kitfox where you can easily go back and forth.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-07-2017, 07:41 AM
paul330 paul330 is offline
Or you could sell the 9 and buy a 9A.....
Otherwise it seems like an awful lot of work for not much return.
Paul
Mercy Air, White River FAWV
ZU-IIZ - "Zeus"
2017 Donation Made
Old 03-07-2017, 07:44 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
I went from a flying 9A to a 9. The reverse should be similar, although I think it might be a bit more difficult overall. You need a new engine mount, gear leg weldments (if going from 9 to 9A), and gear legs (3). Need to remove the tailwheel & spring (easier to leave the weldment in place unless you are still building), and probably move the brake lines around. Also need to cut holes in the fuselage for the gear legs to mate with the weldments and a slot in the cowl for the nosegear leg. Depending on configuration and whether there is interference with the nosegear socket on the engine mount, you may also need to shift a couple things around on the firewall. Adding steps would be optional.
Probably a month or two worth of work (on a part-time basis) but could be done in two weeks if you worked on it pretty hard. In my mind, the most difficult part is going to be adding the gear leg weldments because of the need to pull the wing bolts and working in that confined space.
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 03-25-2017, 04:59 PM
jbenevides89 jbenevides89 is offline
Call vans, they have all the parts you will need listed for the conversion. According to them its a pretty common thing. I have a 9a kit but it will be built as a 9.
Old 03-26-2017, 10:02 AM
n82rb's Avatar
n82rb n82rb is offline
gotta ask, why would anybody want to put a training wheel on their RV?
bob burns
RV-4 N82RB
Old 03-26-2017, 12:10 PM
RV9A Bill RV9A Bill is offline
Default Training wheel
Because some of of us are not skilled in the art of flying a tail wheel aircraft, but in our unskilled way still flying RV aircraft.
RV9A Bill
RV9A 789BT flying
