Old 03-06-2017, 04:51 PM
ClarkieSr ClarkieSr is offline
Default TS Flightlines brake lines
Has anyone installed TS Flightlines brake line hoses from the bottom of the fuse to the brake caliper. If you did, could you tell me how you installed them on your -10 and/or send or post some pics for me
Tom Clark
N646LC
80% complete
Old 03-06-2017, 06:06 PM
togaflyer togaflyer is offline
Tom I sent you an e mail.
Old 03-07-2017, 08:11 AM
Raymo's Avatar
Raymo Raymo is offline
I have them on my -7A (now flying) but not sure that will help you.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 03-07-2017, 08:27 AM
Really dont have alot of install pics from clients. Gee wish I did!
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 03-07-2017, 09:04 AM
Dorfie Dorfie is offline
Default Got them installed
I very muck like the braided lines. To my liking they are a little too long. About 1.5-2 inches shorter would be better (have not measured). Securing them to the front of gear leg all the way down, they end up with a loop going forward at the bottom that I think puts strain on the hose and caliper connection. I had to enlarge the hole in the wheel spat to accommodate the loop. It is still all inside the lower intersection fairing though but only just.
Johan
Dorfie
RV10
2018 dues paid with a smile
Old 03-07-2017, 09:19 AM
rleffler's Avatar
rleffler rleffler is offline
Tom Clark
N646LC
80% complete
Install them just like the aluminum ones in the plans.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-07-2017, 09:29 AM
WE make ours 31.5 inches long straight and straight; straight and 90* for the Matco calipers using a straight 816 nipple in the caliper to clear the pants bracket. WE dont wrap the hose around the axle like the aluminum tube in the plans call for. The extra (little) slack at the front of the axle allows the caliper to move without binding.
We do this type of install on most all RV models. Yep some builders like the long hose version to wrap around the axles, and we can certainly do that. There are ALOT of RV's flying with our standard package and no issues. WE have a few here at 3J1 that I monitor.
Tom
Ridgeland, SC
Old 03-07-2017, 09:34 AM
Auburntsts's Avatar
Tom
That's how I did mine. Straight down the leg and then to the fitting on the caliper -- no loop.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 03-07-2017, 09:52 PM
Default Me Too
Yep, straight down the leg and right to the Matco caliper.
Thanks Tom!
Awesome service, as usual!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 03-08-2017, 02:00 PM
flion's Avatar
flion flion is offline
It took me a while to get the picture up on my site #hostingproblems. But now that it's there, I hope this is useful. Since the lines are flexible, you don't need the loop. Enough slack at both ends for flexing. Nicely made hoses; I would do this again in a heartbeat.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
