Old 03-06-2017, 10:15 AM
Brent 801's Avatar
Brent 801 Brent 801 is offline
Default Canopy Attachment Meathod
Has anyone used Sikaflex to attach the canopy on a 14? If so, any advice?
Built and flying since 2012 RV-8 81764
Building RV-14A 140229
Donation 12/17
Old 03-06-2017, 03:53 PM
mrhorspwr mrhorspwr is offline
I just did my canopy and i have to say, It went very smooth with the screws. As long as you use a dull drill bit you will have no problems with drilling the canopy. One thing to consider before using sicaflex is what do you do with the pre drilled holes in the skins. I assume you just let the glue ooze out of the holes and grind it down after it dries. However i cant imagine the glue staying inside a #30 hole in a .025" thick skin. In a couple years i would expect it to crack and fall out. I have dealt with some good glues designed for use on aluminum but none of them are that good.
Mat -builder assistant
started Rv14 May 2016
emp kit and fuse kit done
wings almost done
canopy done
Old 03-07-2017, 03:16 AM
salto salto is offline
The side skirts could be easily remanufactured without the screw holes. Nothing complex there.
I intend to follow plans and screw were recommended. A question I have for those that have completed this step is there a need to run some sealant between the side skirts and plexi or can you just rely on the channelling to drain any moisture flying or on ground.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 03-07-2017, 04:54 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Sealant
I do not know for certain that sealant is needed, but I did in fact use some. The other thing to consider is to be certain to oversize the holes in the plexiglass and not torque the screws any more than required. You need to have the plexi expand and contract within the frame.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 150+
2018 Dues Paid
Old 03-07-2017, 06:57 AM
I did not put any sealant between the glass and retainers. After the canopy and back window were finished, I applied an edge seal around the perimeter. Just mask aprox an 1/8 in onto the window and mask the edge of the metal next to the window. Mix up some sealer and apply it with a popsicle stick. Use soapy water or spit to smooth the edge seal then peel your tape.
wings almost done
canopy done
Old 03-07-2017, 07:24 AM
Sika doesn't harden, so no cracks.
Old 03-08-2017, 09:06 PM
KeithB KeithB is offline
I used Sikaflex on my RV-14A - it took a lot of planning but I'm quite pleased with the results. I would do it again.
My primary resources were the blogs by Bruce Hill (RV-9A) at http://www.overthehills.com/RV-9A-Project and Bruce Swayze (RV-7A) at http://www.europa.com/~swayze/index.html.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >240 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
