Old 03-05-2017, 07:35 PM
RVdreamin RVdreamin is offline
Default One or two steps
Guys....I purchased a left and right step for the 9A, but I got to thinking if I could get a way with one on the left side (Realize none are required). The single passenger could simply enter on the left side and step across to the right side. Bottom line if you want a step will just one work fine? Is there an advantage to having two?
Jimmy Black
RV-9A
Started Emp 10/9/2013 Finished 10/16/14
Wings finished April 9, 2016
Fuselage received Sepember 12, 2016
KX59
VAF paid 2017
Old 03-05-2017, 07:44 PM
Install both. I put only one thinking of an occasional passenger. Couple hundred riders later I wish I've installed another one
jimbo jimbo is offline
One will work. I put in 2. The advantage of 2 is when you want to get in on the other side so you don't have to walk around the plane while your working on something inside the cabin, or you and passenger get in or out at the same or nearly same time.
I'd probably put in 2 again.
Jim
RV9a
Old 03-05-2017, 08:04 PM
Jesse's Avatar
Jesse Jesse is offline
I agree. Put both.
352-427-0285
jesse@saintaviation.com
Old 03-05-2017, 08:13 PM
Mel's Avatar
Mel Mel is offline
Just always be aware to assure that both are not used at the same time.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 175hp O-320, 3-Blade Catto (since 2003)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-05-2017, 10:00 PM
Michael Burbidge Michael Burbidge is offline
Default Both...
Absolutely both in my opinion. Silly not to.
And yes, one time, without thinking I and my passenger were on the steps at the same time. Almost banged the tail, but I stepped off quickly.
Michael-
Michael Burbidge
Sammamish, WA
RV-9A Flying–265 hours so far!
Last Donation: December 2017
Old 03-06-2017, 06:04 AM
Tooch Tooch is offline
Default fall off
Put on two, then the one on the passenger side will vibrate off like mine and so many others did, so you will be left with one. I haven't fixed mine and one works fine.
Old 03-06-2017, 08:07 AM
As always...great feedback....What is the mod that was mentioned?
Jimmy Black
RV-9A
KX59
VAF paid 2017
Old 03-06-2017, 08:40 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Mod is reinforcement of the welds on standard steps. They tend to crack over time if not reinforced. Easier to do before installation than after.
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 03-06-2017, 08:53 AM
johnbright's Avatar
johnbright johnbright is offline
Default step reinforcement
See #4 here. Look at photos and see if your steps are already reinforced.
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Dual alt, single batt. Wiring and IP CAD files here
Newport News, Va
