Go Back   VAF Forums > Main > Reviews
Old 03-06-2017, 01:03 PM
rv8ch rv8ch is offline
Default Carb loss question?
Any current Kitplanes subscriber may click here for a past article, written following a trip to the Airflow Performance school:
http://www.kitplanes.com/issues/33_3...d_21479-1.html
Great article, Dan!
One question that is perhaps answered in the class, and I didn't quite get from the article, is what is the relationship between the "carb loss" and either power or efficiency of the engine?
For example, you show:
Code:
RSA-5  12.75 inches
FM-150 10.0  inches
FM-200  4.0  inches
RSA-10  4.9  inches
FM-300A 2.6  inches
What would be the difference in "performance" of an io-360 with a FM-150 and a FM-200 or a FM-300?
Thanks!
Mickey Coggins
http://rv8.ch
Old 03-06-2017, 01:22 PM
Raymo's Avatar
Raymo Raymo is online now
Thanks!
From what I learned in the class, my understanding is that larger engines pump more air and therefore need a larger fuel servo/regulator to provide more fuel at higher RPMs, which translates to more HP.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, Catto 3 blade NLE, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines (AKA Hoser)
NSDQ
- - 2016/17 donation compliant - -
Old 03-06-2017, 02:10 PM
DanH's Avatar
DanH DanH is online now
Carb loss is simply a reduction in manifold pressure. All things being equal, replacing an RSA-5 with a FM200 would increase manifold pressure by 12.75 - 4 = 8.75 inches of water, or 0.64359 inches Hg.
Things are not always equal. For example, a different manifold may be necessary to get a larger mounting flange diameter.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-06-2017, 03:13 PM
ppilotmike's Avatar
If that's the whole story, then I think it's unfair.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/13/17
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
