Go Back   VAF Forums > Model Specific > Rocket
Old 03-04-2017, 09:06 PM
RV-4 RV-4 is offline
Question RV-8 TAIL ASSY ON A ROCKET
Hello Gents
Any harm in installing a RV-8 Tail assy on a Rocket?? I know of one and was wondering if there might be any do's & don'ts..
Bruno
2018 Due paid gladly
Old 03-05-2017, 07:55 AM
N395V's Avatar
N395V N395V is offline
Which Rocket?........................................... ............................................
Milt Concannon
Old 03-05-2017, 09:03 AM
flynwest flynwest is offline
Default 8 tail
Bob Mills put one on his Rocket 6
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2018
Dan "Nordo" West
Old 03-05-2017, 09:04 AM
Toobuilder's Avatar
I didn't build it, but my Rocket has an -8 tail.
I understand from Mr. Mills that the taller tail is a speed penalty. Out of concerns over the higher speed of the Rocket and potential susceptibility to flutter, I also removed the rudder trim tab the builder installed. It was quite sloppy and I have not missed it one bit.
Michael Robinson
______________
RV-8 - Flying
Old 03-05-2017, 09:49 AM
Thumbs up RV-8 TAIL ON A ROCKET
Milt
It is a HR 2, it looks good on the airplane but was wondering if it could affect the aircraft in any way...
Bruno
Old 03-05-2017, 10:52 AM
Steve Barnes Steve Barnes is offline
Default I have a RV8 empennage fairing on my Super Six too
When I built my Super Six (sister ship to bob Mills) I had an unused RV 8 empennage and installed it during the build. Has worked perfect for 1250 hours. I not sure if Bob has an RV 7 or 8 empennage on his 6.
Steve
Old 03-05-2017, 11:32 AM
I built two HRIIs using the RV8 tail. They fit fine and I used the 8 tail for two reasons. It was easier to build then the 4 tail and also it had a counterbalanced fin. I have not flown a HRII with a RV4 tail but my RV4 had, at times, a tail wags the dog kind of yaw situation. My rockets with the 8 tail did not have this syndrome. That is the good news.
On the negative side:
The 8 tail is heavier and we really do not want that extra weight back there.
Also the elevators on the 8 are adequate but a wider chord would be better. I could run out of trim in some loading conditions and I wonder how well the plane would fly in an engine out scenario.
Although I never made any measurements I wonder if the RV7 elevators would work on the 8 stab?
While building the 8 tail I would recommend reinforcing the forward VS attach point as well as the forward HS stab spar. My HRIIs had stock engines and were fine with the stock tail, however if you plan on higher speeds be aware that you may be in uncharted territory.
It is great to see some renewed interest in Rockets. They are a joy to fly and I can hardly wait for spring weather!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 03-05-2017, 12:21 PM
jrs14855 jrs14855 is offline
Default Tail Wags the dog
That is normally an issue with the folded trailing edge skins. I had a hangar neighbor years ago with a then brand new RV4 and it was a pretty significant issue based on his description. I looked at it and the skin at the trailing edge was bulged out significantly. I told him to squeeze the trailing edges and he said the problem went away. This discussion seems to come up repeatedly.
Once again I recommend Barnaby Wainfans excellent article on this subject a few years ago in Kitplanes.
Old 03-05-2017, 03:32 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default It will fit but...
I would suggest a few beef-ups to stiffen the structure for Rocket speeds - make your own .040 spars for example. Also the elevs are a bit on the small side, as obvious on a 200HP/metal prop RV8. It won't 3-point solo without some ballast (I suggest a 120lb PAX in the back seat - possibly one on the female side of things) or 1/2 flap, but to some that characteristic is not a problem.
Other than that, it fits up fine! Use 1"X1" angle at the H Stab fwd spar attach in the fuselage at the #10 bulkhead (under the aft deck plate). There is more to the aft fuselage story...
Remember the airframe Vne is a TAS number.
Carry on!
Old 03-05-2017, 03:43 PM
scsmith scsmith is offline
Wait! Don't confuse a dutch-roll yaw oscillation with a vague or bi-stable rudder issue. Two very different things. A poorly formed trailing edge will cause the latter, but not the former.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 490 in 8-1/2 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
