Old 03-04-2017, 05:04 PM
kaweeka kaweeka is offline
Default LED landing lights
I just replaced the 75W halogen wingtip landing/taxi lights on my -9A with the following. No noise, $22.59 for the pair on Amazon. They seem bright as the halogen without the excessive heat or power draw.
Soraa 00957 - 9 Watt - LED - MR16 - 75 Watt Equal - 3260 Candlepower - 3000 Kelvin - 80 Color Rendering - 25 Deg. Narrow Flood
Just in case anyone is interested.....
RV-9A N435KR
IO 320 B1A Dual LS Plasma III
G3x touch
Old 03-05-2017, 07:16 AM
thx for the report. that's probably the way I'll go for now.
Old 03-05-2017, 08:53 AM
krw5927 krw5927 is offline
Thanks. You said $22.59 for the pair? That's the price I'm seeing for a single. Do they come in a 2-pack?
Kurt W.
RV9A
FLYING!!!
Old 03-05-2017, 09:22 AM
My mistake,
Ordered from 1000 bulbs
Order Summary
Item(s) Subtotal: $34.54
Shipping & Handling: $4.99
Total before tax: $39.53
Estimated tax to be collected: $0.00
Grand Total: $39.53
RV-9A N435KR
G3x touch
Old 03-05-2017, 12:06 PM
Wonderful, thanks for the update!
Kurt W.
RV9A
FLYING!!!
Old 03-05-2017, 12:35 PM
pyolet's Avatar
pyolet pyolet is offline
I tried the Soraa LED's as landing lights last summer and I experienced way too much noise so went back to halogens. Guess it depends on the wiring...my builder grounded all the lights including AeroLED Pulsar nav/strobes, into the wingtip rather than shielded grounds back to the panel, so I experience some strobe feedback as well, depending on VHF frequency. Hope they work for others. Woody.
RV-Super7, IO-540, Hartzell 80" blended CS. Flying since 2011. Day/night IFR.
=VAF= donor 2018
Old 03-09-2017, 10:23 AM
Default installed Soraa 00957 - 9 Watt
I like them. No radio noise. I had a slight humm from the halogen but not from Soraa. They are much brighter than the 50W halogens I was using. My wiring is grounded at the wing tip rib. I'll upload a photo in the next couple of weeks for comparison. The current draw initially was 0.9A but settles at 0.84A after a minute to warm. That's about 10W. It's amazing what these bulbs can do. I poked around and found some ebay version claiming 15W MR16 spotlight for $3.50 each. I ordered a couple just to verify them. 15W (quoted 6000+ lumen) is getting close the PAR36 18W light, amazing. The weight on the Soraa bulb is just 47g, that is the highest lumens to weight ratio light I have seen.
Old 03-09-2017, 11:51 AM
kentlik's Avatar
kentlik kentlik is offline
Price drop! If these are the same bulbs $17.27
https://www.1000bulbs.com/product/116683/LED-00957.html
FYI
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-09-2017, 12:13 PM
moosepileit moosepileit is offline
IF you have PAR36s and don't mind spending a bit to have less amperage, the same if not better light than 55w halogens, no noise and dead simple install, read on.
I like the 10 degree Rigid spots. RIGID INDUSTRIES RS PAR36 LAMP 1800 LUMEN | (62110). They are $142 each. There is a 3400 lumen version which sounds overdriven. The current is halved with 1800 lumen and the same as 55w halogens with 3400 lumen.
For my 1800 lumens, the $45 KUNTZLEMAN wig wag works great.
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 03-11-2017, 02:27 PM
Default some comparison
marginal photos. 50W halogen on the left, 10W LED on the right. the left side is pointed downward for taxi.
10W LED on the both sides. On a four mile ILS final they said they could see me fine. good enough for me.
