Old 03-02-2017, 01:41 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default RV14 second battery
What is a good location on the firewall for a second battery.
Especially anyone who has mounted a second battery and found that it was the ideal location or found that somewhere else would have been better.
Jeff Warren
Simpsonville, SC (SC47)
1946 Bellanca Cruisair 14-13-2 (71 YRS OLD 8/15/17)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 03-02-2017, 03:02 PM
asw20c asw20c is offline
I recently discovered some corrosion on the belly of my Cessna 180 that was later traced back to the battery vent tube a few feet forward on the bottom of the fuselage. Apparently for a reason I still have not determined, the fairly new battery I installed decided to offload some of its electrolyte that discharged through the vent and resulted in the bit of corrosion I found. The reason I tell this story is because my A&P suggested that maybe at some point it was overcharging and boiled off, so it got me to thinking about batteries mounted on the firewall in an environment MUCH hotter than underneath my baggage area. There were some posts here not long ago with people offering temperatures they have recorded in this very area that were hot enough to be a real problem (I would think) for a battery with plastic housing. Are batteries designed to withstand boiling temperatures as can be expected in this area? I get the desirability of mounting batteries there-favorable CG, a lot less heavy cable required, easier access, etc. But what about temperature?
Empennage Complete Except for Tips
Wings Underway
Old 03-02-2017, 05:55 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Batery temp
I think your AP was right to suggest over-charging. This EX900 battery on the firewall of my RV9A shows a max temp of 150 degrees f after one year including Arizona summers. I do not open the oil door to help cool.
John Morgensen
RV-9A N946PM 500+ hours since 2013
Nevada/Arizona
Old 03-02-2017, 07:08 PM
N941WR's Avatar
N941WR N941WR is offline
Why do you need a second battery?
Whatever EFIS you pick will have its own backup battery.
If you pick an ignition that can run independently of your aircraft's electrical system, what else do you need?
Jeff, give me a call so we can discuss your options.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-07-2017, 01:16 PM
Cliff Goldstein Cliff Goldstein is offline
Default 2nd battery
I installed EFII so wanted the redundancy of 2nd battery. Peace of mind.
Mounted second battery inside over the pilot rudder pedals on fire wall.
Just below structural channel with enough tilt clearance to take battery out and still have full rudder pedal travel.
Since I mounted my engine ECU's on inside firewall, I added access panels on both sides of the boot cowl. It then allows easy access to ECU and battery. And if u really wanted to move the rudder pedals, you could do it without standing on ur head.
cliff
Cliff@eclipseseal.com
Old 05-07-2017, 04:42 PM
Carl Froehlich's Avatar
I have posted on this before. A single PC-680 battery is inadequate for RVs if you plan on any operation other than local VFR. It simply does not have the reserve electrical capacity for IFR work. I'm not a big fan of EFIS backup batteries as I find they typically do not have enough capacity if you really need them, and dead weight for most of their life. There are better power distribution options if you take the step of adding a second battery. If you consider approach, look at the PC-625 battery. It is a little lighter, better AH and CCA ratings than the PC-680, and I find it a better form factor for mounting.
One other point that has been previous discussed. It seems the current PC-680 battery is not as good as it once was.
Old 05-07-2017, 05:42 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Do you find these statements to be just as true?
  • "A non-certified aircraft is inadequate if you plan on any operation other than local VFR."
  • "A single engine aircraft is inadequate if you plan on any operation other than local VFR."
  • "A single pilot aircraft is inadequate if you plan on any operation other than local VFR."
  • "A non-turbine aircraft is inadequate if you plan on any operation other than local VFR."
  • "Flights performed under FAR part 91 are inadequate if you plan on any operation other than local VFR."
I understand when you're coming from - risk identification and mitigation to suit one's own level of risk acceptance is something that I don't think enough RV builders perform either. But to make a statement that a configuration used by many, if not most, RVs is inadequate for flights performed by many, if not most, RVs doesn't pass the sniff test.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 05-07-2017, 07:00 PM
Ok - I'll bite.
Time has marched on. Most people building RVs for IFR operations are doing electric dependent panels. Reserve electrical capacity defines how long you can maintain those panels while IFR when any element in the power distribution chain fails (you pick you failed competent - the basic 1960 Cessna power distribution that many emulate has many more single failure modes than just the simple alternator failure).
Do a test. Sit in the plane with the panel up and engine off. How long does your EFIS, XPDR, GPS navigator, comm, autopilot and such stay on line? Now do the same test and simulate your master solenoid failing by opening the master switch. Do you have anything left running? If so, how long?
I design for maintaining a full panel after any single electrical power distribution component failure. In the worst case, this results in single battery with no alternator operation - a reserve of about 90 minutes if you shed non-vital loads. If both batteries are available I have about the same electrical endurance as I do fuel. That is my risk tolerance. Add to that the straight forward approach to get that level of performance and the design decision is easy.
I've installed dual PC-625 batteries setups in four RVs, operating over 15 years. The design has proven its worth to me and the other RV owners.
On the RV-10 I even added a standby alternator as further mitigation as the power hungry panel ate away at some of my reserve capacity. It is diode isolated to prevent a single fault from taking it out as well. I offer that just adding a standby alternator to a standard single battery install protects from one fault only, a loss of primary alternator.
Old 05-07-2017, 07:16 PM
ChiefPilot's Avatar
Ok - I'll bite.
Well, actually, I do know I have 42 minutes of reserve juice should the alternator fail. This compares somewhat better than the electrical analysis spreadsheet I built for the design would suggest (I designed for 30 mins), so I'm happy. And I specifically chose to not worry about the master relay failing, because it's typical failure mode is failing "on" when it fails during operation as identified via FMEA. But all that is kind of beside the point.
The main point of my post was that your opinion was posted as fact - which is most certainly is not; it's an opinion and should probably be clearly called out as such. A well reasoned opinion, with thoughtfulness and analysis to be sure, but an opinion nonetheless that doesn't apply to many (if not the overwhelming majority) of RVs that have a single PC-680 as shown on the plans and which are flown on more than just local VFR missions daily. I think are probably more risk averse than most - nothing wrong with that - but the operational history of the RV fleet hasn't demonstrated that planes flying other-than-local-VFR missions are falling out of the sky due to electrical failure either.
Old 05-08-2017, 08:31 AM
[quote=ChiefPilot;1171480]Well, actually, I do know I have 42 minutes of reserve juice should the alternator fail. /QUOTE]
Not to beat a dead horse, but I note that unless the single failure you list happens at just the right time during your IFR flight, you have less electrical reserve than the required minimum fuel reserve.
It does not require a lot of money or weight to build a more robust power system that can maintain panel operation after something fails. Considering the trend to EFIS backup batteries such an approach may even save some weight and money.
My point is not to argue risk tolerance. If there is little cost to mitigating potential failures, why not just do it?
