Old 03-01-2017, 08:28 PM
scsmith scsmith is offline
Default Suggestions for a retractable tray
Looking for ideas.
On my RV-8, I would like to have a retractable tray that slides out from the instrument panel lower lip, that would hold my tablet (iFly720). Ideally when retracted, it would project out from the panel some minimal distance, and perhaps provide a feature for hanging a headset on. When pulled out, it would present the full view of the tablet.
I'd like to do this with a bare minimum of intrusion into the existing panel support structure.
What have some of you done?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 470 in 8 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 03-01-2017, 10:17 PM
Blain's Avatar
Blain Blain is offline
Wouldn't you lose valuable stick length?
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 03-02-2017, 08:59 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Also consider knee room, wouldn't work for me... Put my iPad mini on a ram yoke mount attached to the right canopy rail... Movable, works well...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 30, 2017
Old 03-02-2017, 09:11 AM
I'm thinking over to the right side, under the ignition switch and hobbs meter. Doesn't take away knee room either (as long as it doesn't project downward too much or inboard too much)
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Old 03-02-2017, 09:56 AM
walldan's Avatar
walldan walldan is offline
Default A few different ways..
There are a few ways you can do this... But I have a few questions.
Do you want it to always hold the tablet (store it when closed) and allow you to see it when open?
How do you want the tablet positioned when opened? I would assume screen parallel to the panel?
Does the tablet need to be secured in the tray when it is open and being used? Do you have a method to secure the tablet in mind?
DW
President of EAA Chapter 992
Hatz Biplane under construction
Future Builder RV-6/7/9/14 <Green light to order... must decide!
Retired Volunteer Firefighter & Active EMT
Old 03-02-2017, 10:10 AM
Yes
No, it can remain flat. I can see it fine that way.
Probably velcro. Or maybe some kind of spring clip so it is easy to remove.
I'm really thinking of a very light-duty sliding tray.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
