Old 03-01-2017, 01:25 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Skirt for Todd's canopy
I have nothing but issues with the skirt for my canopy.
Who has made their own skirt and thrown away the van's one. I know the shape is different, but i tried to modify the vans skirt for this, and even had help with it.
Looking at just making a new one from scratch.
Who has done it? I am not very good with the glass, so any hints and help would be appreciated.
Ive read Dan's (and others) posts about glass work.
This part of the build has completely stalled me.
Don
RV-8 build
Working on the finish kit!
C-GLOV (Reserved)
http://www.mykitlog.com/Don%20Patrick
2018 donation contributor.
Old 03-01-2017, 04:51 PM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
Default I made mine
I did my own skirt and made it structural. This eliminated the need for the steel structure, other than the forward steel bow. It has a foam core making it very light and strong. Lots of pictures here,
Www.facebook.com/radialconversions
Flying as of 1-12-2016!!!!!
See the worlds only radial powered RV-8 at;
www.facebook.com/radialconversions
Or at
www.radialconversions.com
Old 03-01-2017, 06:15 PM
judoka5051 judoka5051 is offline
Default Been there!
I cut few couple of vertical slits in the problem areas. Then once I'd coaxed the skirt into the correct shape I added a couple of layers of glass over the slits to keep the shape until I could add material to the back. It really didn't take that long. I ended up with a very tight fit while sitting on the ground, but still saw 1/4 inch blowout at fast cruise speeds. So much for a leak free skirt!
Lance Logan
Stuart, FL
Plane at X58
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
RV8 Project purchased (Can't help myself)
Old 03-01-2017, 07:41 PM
DonPro DonPro is offline
I had to hack up the back of mine. Todds are a different shape back there.
Don Prosise
N642DP RV-6 180,CS,Flying
N848DP RV-8A IO-360-A1A Flying
Chandler, AZ
Old 03-01-2017, 09:16 PM
Blain's Avatar
Blain Blain is offline
Todds canopy, Vans skirts and Sikaflex. Came out very nice. Didn't fight it at all.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 03-02-2017, 06:11 AM
A2Jake's Avatar
A2Jake A2Jake is offline
Default Skirt
Check this thread:
http://www.vansairforce.com/communit...t=canopy+skirt
RV-8 Project Rebuild
RV-8 Fastback New build
Cessna 195
Old 03-02-2017, 06:50 AM
David-aviator David-aviator is offline
Don
I have Todd canopy and like others, had to cut aft part of skirt and re-glass to get to fit reasonably well.
If this is first fiber glass work, get West slow epoxy system and RAF bi-directional glass from ACS. That weave shapes nicely to contours.
Cover fuselage area with some plastic material or duct tape to protect it and have at it. Use just enough epoxy to wet glass. Minor lumps and bumps can be filled before paint.
I agree, the canopy is one bear of a job with any Vans airplane. Its a bigger bear with the Todd canopy. It is much bigger bear yet to redo entire skirt.
I considered it but modified aft end of Vans skirt instead.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2018 This place is worth it!
Old 04-01-2017, 01:20 AM
dlomheim dlomheim is offline
Default Skirt blow out in cruise
Originally Posted by judoka5051 View Post
...I ended up with a very tight fit while sitting on the ground, but still saw 1/4 inch blowout at fast cruise speeds. So much for a leak free skirt!
Do you think a layer of carbon fiber would have helped to stiffen the blow out area up enough to keep it in place?
Doug
Old 04-01-2017, 08:46 AM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
What David and others said.
I too have a Todd's canopy and used Sikaflex to bond the canopy to the frame. The aft end of the skirt took some surgery to get a good fit.
I recall getting a tip from someone about having to raise the the skirt, higher than expected, to get a good fit. In the end, mine came out well.
Rather than using carbon fiber I bonded an aluminum plate on the centerline on the aft end to both help with the fitting process and to add strength.
Yes, its frustrating. Keep at it and you will find the right geometry
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
