Old 03-01-2017, 02:17 PM
Redbud40 Redbud40 is offline
Default Rv6 glass panel fit
Has anybody upgraded to a 10inch left 7 inch right setup? Or a two screen 10 inch side by side? Curious as to the fit and where/ and how the other panel components or remote components fit. Thanks.
Mike R
Mike Robinson
RV-6a N731CK
52F
Old 03-01-2017, 03:02 PM
Ralph Inkster Ralph Inkster is offline
Vans does sell an oversized panel blank, if more space is needed.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 03-01-2017, 03:12 PM
cbennet1 cbennet1 is offline
Mike R
Take a scroll through the "Show us your panel" Sticky thread. A picture tells you how much space you'll use and what else will fit where better then someone's description.
BTW, I'll be facing the same dilemma when I undertake panel update number 2!!!
Craig
Craig Bennett
321GT Flying RV6
2017 dues paid, how about you?
Old 03-01-2017, 04:11 PM
lr172 lr172 is offline
I just shoe-horned a GRT 10.4" Efis into my stock RTV-6 panel, along with a mini-x (necessary, as I had no more space for my steam backup instruments). It is kind of tight but it works. I can shoot a pic this weekend.
This replaced dynon legacy gear and steam backups
N64LR
Old 03-01-2017, 04:48 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Been planning a AFS 5600 10"
It will fit my stock panel without serious issue, but I may go ahead and use the deeper panel, since I already have the blank. I have a Dynon EMS 120 and D10A which I will keep for engine instruments and backup.
I have a pic of my mockup, if you would send me an email, I will send it to you.
Planning on doing my "big buy" after Sun n Fun.
Ron
RV-10 Co-built (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV)
IO360, 180HP/CS, AFS 5600T, G650, VIZ385
Very Happy Contributor
Based at KCLW (Clearwater, FL)
Old 03-01-2017, 05:04 PM
Ironflight's Avatar
VAF Moderator / Line Boy
to answer the original question directly - yes, our RV-6 has a large screen G3X Touch on the left, and the small Touch on the right. The radio stack is in the original position.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-01-2017, 05:35 PM
Paul, is there a picture of your setup lurking around? I found one but looks like they are older garmins side by side with radios on the right. Thanks.
Mike Robinson
RV-6a N731CK
52F
Old 03-02-2017, 11:41 AM
219PB 219PB is offline
I just had Steinair cut a panel out for me. It has two 10" Dynon HDX screens incorporated.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
Old 03-02-2017, 01:48 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
You can fit (3) 10" screens in an RV-6 if you want:
Our general recommendation is to not put the second screen all the way over on the right. Keep it in the middle. You'll be using it a lot, and it should be close to you. The guy (or gal) in the right seat can see stuff in the middle just fine so you can put the PFD on there when they want to fly, but it's much more optimal for the 99% of the time where it's being flown from the left seat.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 03-02-2017, 05:36 PM
Thanks everyone now if Dynon or Garmin have an amazing sun n fun sale I'll have to drop the coin.
Mike Robinson
RV-6a N731CK
52F
