Old 02-27-2017, 10:23 AM
KazooRV-9A KazooRV-9A is offline
Default GAS-5 Gascolator, what's in these things?
I bought a GAS-5 Gascolator and thought I'd have a look see what's inside one.
I took the retainer plate off, 4 screws, and could not pull off the bowl, seems pretty fixed....
So, does anyone know what's in these, meaning IS there a filtration element of some kind? Ever replaceable?
My old C120 has a John Deere gascolator with a filter element that you can clean if needed. What's in the GAS-5? Why doesn't the bowl come off?
Andy C.
Old 02-27-2017, 10:40 AM
snopercod's Avatar
Default rotate the bowl and pull down
Per the Installation Drawing
Remove the four screws and retainer plate. Rotate bowl while pulling down.
Yes, there's a filter screen in there.
(2018 dues paid)
Old 02-27-2017, 11:01 AM
I'm here to tell you, that bowl is in there!
Does anyone have a picture of one apart?
A.
Old 02-27-2017, 11:22 AM
The "O" ring is stuck-----try tapping the bowl with a soft faced mallet to break it loose. (The bowl is machined from a billet, stronger than it looks, so don't be afraid to apply a bit of force). Then turn/pull like previously mentioned.
The drawing linked above pretty accurate.
Watch out for the plumbing on this, only one inlet but two outlets. See this thread. http://www.vansairforce.com/communit...d.php?t=125673
Old 02-27-2017, 11:53 AM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Just turn it while pulling, it will come out.
Troy Branch
RV10 Built and Flying Since Feb 2009
850hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid 2017
New Family Travel (B)Log: http://www.amateurbuiltfamilyfun.com
Old 02-27-2017, 01:28 PM
Ron B. Ron B. is offline
Mine came out hard also, but it will need to be inspected annually. Part of your problem might be that the base is not fixed. Mine was that it was in a hard place to access.
I has trouble getting the screen out, but thinking back I will have to look closely to see if it needs to be removed. Will the dirt (if we have any) be on the underside (visible without moving the screen)?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 02-27-2017, 01:37 PM
Thanks for the inputs, I'll eat my Wheaties and try disassembly again!
Old 02-27-2017, 03:53 PM
DHeal DHeal is offline
Shoot a little thin lubricant (I use silicone spray) around the bowl/base joint to facilitate the separation.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 620+ hours (as of Apr 2018)!
VAF donation through June 2018.
Old 02-27-2017, 04:01 PM
I have been using NAPA SilGlyde for many years for "O" rings.
One tube will last a lifetime.
http://s7d9.scene7.com/is/image/Genu...Company/215803
Old 02-27-2017, 06:04 PM
snopercod's Avatar
Default DC-4
DC-4 works well. Also, Parker O-Lube.
(2018 dues paid)
