Old 02-26-2017, 08:11 PM
Tmartin66 Tmartin66 is offline
Default Elevator trailing edge-proseal as opposed to tape
OK Gang, I am about to assemble the elevators and plan to use proseal as opposed to the double sided tape. My plans only describe the tape method. Currently my plan is to proseal the trailing edge at the same time I proseal the foam ribs and cleco the trailing edge together. Then let it cure for a few days before I rivet. So is this how others have done it or is there a better way. I'm a newbie so any advice is appreciated.
T. Martin
RV-14A under construction
N114TM reserved
Dues paid 2018
Old 02-26-2017, 08:17 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
That works. For the RV-10 I did similar but I clamped the trailing edge between two pieces of 2"x2" steel angle iron to make sure the trailing edge was straight. Double flush rivets came after cure. This might be more important for the flaps and such, but I did it anyway for the tail.
Old 02-27-2017, 02:57 AM
salto salto is offline
I tried all methods, Elevator and rudder double sided tape, flaps proseal and ailerons nothing at all just very carefully squeezed up the rivets all worked out fine.
I think the trick is make sure you prep everything as perfect as possible. ie good dimples, correct depth countersinks and straight /flat work table.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 02-27-2017, 04:41 AM
Ron B. Ron B. is offline
I tried the tape on one edge and did not like the results so I went back the RV-10 method of using Proseal.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 02-27-2017, 04:56 AM
Reflex Reflex is offline
I tried both. Prefer the Proseal method. Gives time to work and stick well. Remember to scuff/clean both sides before applying the Proseal. Used a foam roller to apply, worked great.
Fred
Dues Paid for 2018
RV-14
Working on Empennage
Old 02-27-2017, 05:12 AM
mturnerb mturnerb is offline
On the rudder trailing edge I used a method described on "Carl and Rafael" RV-14A build site (a GREAT site by the way - http://www.rv14a.com ). They used JB Weld. This worked great, but I also clecoed to a piece of aluminum bar to keep the edge straight (worked very well). The challenge was separating the bar from the edge when I removed the clecos - JB Weld seeped out around the clecos and bonded to the bar.
I used proseal on the elevator trailing edges - had it already to bond the foam ribs. I liked it - and as others mentioned it's all about the preparation. It was easier to clean up after everything was all bonded up / clecoed.
TB
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 02-27-2017, 07:54 AM
N941WR's Avatar
N941WR N941WR is offline
Do NOT wait for the proseal to dry before riveting. Rivet it wet. If not the proseal will keep the rivets from setting all the way. Over time the proseal will "work", leaving you with loose rivets.
On the -9 the plans call for proseal on the stiffeners, this helps prevent the skin from flexing and cracking at the rivets closest to the trailing edge.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-27-2017, 08:07 AM
shanecfi shanecfi is offline
Default Trailing Edge
I just completed my rudder (14a). For a first time builder I am happy with it. I showed pictures to my EAA chapter and they said it was good. I know it was just a picture, haveing my tech adviser over next week. We shall really see then. I used the tape method and plan to use it throughout the build. Did you use tape on your rudder and if so why do you want to use a different method? I am forever looking at everyone's methods of doing things. After I will be asking my wife to travel with me at 10,000 feet at almost 200 mph. in a machine we built.
Many thanks alll
Shane Barker #140351
Commercial/Instrument
EAA/AOPA
RV-14a Emp. completed and stored
Wings Skins Attached
Old 02-27-2017, 08:15 AM
N941WR's Avatar
The problem with this forum is that someone will post something that "works good" but has never flown. Then others start to follow what could be a bad example and have problems after a couple of hundred hours of flight.
It is best to follow what Van's recommends and not deviate from it.
Bill R.
SC86 - Easley, SC
Old 02-27-2017, 09:22 AM
Van's recommends one method on the RV-10 and another on the RV-14. Same ailerons.
Thanks Ron
RV-10 SOLD
RV-14 Flying
