Old 02-26-2017, 07:49 PM
salto salto is offline
Default Drilling Canopy
RV-14 plans say to pilot drill canopy with #40 and then a #27.
Reading /watching tips on google and YouTube there is a lot of advice not to drill a pilot hole.
I've ordered the acrylic drill bits, what was being said about rake and angle all made sense it's just the pilot hole issue that I'm procrastinating over.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 02-27-2017, 08:55 AM
Janekom's Avatar
Janekom Janekom is offline
Why do you not use Sikaflex ?
Jan Hanekom
South Africa
AP 325, AMO 1256
http://www.rvbits.com
RV10 - ZU-XOX - (Fuselage)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Sold Flying)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2018
Old 02-27-2017, 09:31 AM
BillL BillL is offline
If you don't use SikaFlex, the pilot hole is not an issue with the Avery style acrylic bits. The reason for the pilot is valid. If you want to drill through with no hole to match then use the acrylic bit to mark the hole, then no pilot may be needed. But if you try to hit an existing hole, the pilot bit allows some working room. I found that it was a little challenging to get the drill point perfect aligned with an existing hole. Like shooting fish in water - the plexi affects the visual aiming. Looking straight at the hole, and bringing the bit point to match on the surface, then standing up the drill square with the surface gave me the best results, but techniques may vary. Happy Building.
I should add, dipping the bit in water before drilling (slow rpm) each hole adds some cooling and a little lubrication. I completed another project with lots of plexi drilling and the produced cleanest holes. Relieve the down force as the tip penetrates the far side.
For the total DIYer -
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 02-27-2017, 04:42 PM
mrhorspwr mrhorspwr is offline
Default drill bits
Dont waste your money on drill bits for plexiglass. Instead just chuck a regular bit up and drill some concrete with it for about 10 seconds. It will dull the bit and i promise you wont crack your canopy. As far as using the #40 pilot first. It is dangerous because when u drill the hole up to size, the bit will try to pull itself through to quickly and blow out the back. If you use the pilot make sure you spin up your drill before u put any pressure on the glass. You want the bit to somewhat melt its way thru. High speed low pressure is key. Try drilling a few holes in the tiny amount of cut off from the canopy.
Mat -builder assistant
started Rv14 May 2016
emp kit and fuse kit done
wings almost done
canopy done
Old 02-27-2017, 07:30 PM
That's why it is a good idea to use plexy drill bits (instead of a regular one run into concrete), They cut with zero rake, and wont pull themselves through.
Scott McDaniels
Hubbard, Oregon
Old 02-28-2017, 11:32 PM
OK thanks for all the tips. Light diffraction and not to much pressure exiting the hole with zero rake on drill bit seem to be the important points.
Thanks again. 👍
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 03-13-2017, 07:35 AM
jwoolard jwoolard is offline
Where do you buy these acrylic/plexy drill bits? Cleaveland/Brown/Aircraft Spruce only seem to have them in fractional sizes down to 1/8 - and from the instructions we need #40, #36 and #27
Building an RV-14A with my wife in the UK
Dues paid Nov '17
Old 03-13-2017, 02:07 PM
tomkk's Avatar
tomkk tomkk is offline
I got mine here: https://www.mcmaster.com/#plastic-cu...-bits/=16qnq48
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA Eagles Nest Project; ready for engine & avionics
Old 03-13-2017, 02:47 PM
Mine just arrived from Great Lakes Aero Products.
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 03-13-2017, 03:09 PM
Nova RV Nova RV is online now
I just bought a new set of standard bits and cut down the tips to remove the shoulders like in Bill's post. Took about a minute with the Scotchbrite wheel for all of them and they make nice clean holes in the plastic and no grabbing.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
