Old 02-25-2017, 05:41 PM
SabreFlyr SabreFlyr is offline
Default Drill bits needed for the -14
Getting the tools together for my QB -14 kit which will arrive soon. I'm comparing the tool list on pages 03-02 through 03-04 of the plans with the list of Van's website (http://vansaircraft.com/public/tools.htm). Quite a disparity there in the drill bits required. The website list seems quite limited in comparison and would seem to be insufficient (really, only five sizes?!).
Ray Dosh
LJ45 driver
RV-14 QB #140212
VS done (by previous builder)
Rudder finished & elevators almost done
2017 DUES PAID
Marion, IN MZZ
Old 02-25-2017, 06:33 PM
Ron B. Ron B. is offline
Sizes that come to mind. #40, #30, #33 X 6" , #19,#20, #12, #27, 1/4" 3/16" , 5/16" and 3/8".
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 02-25-2017, 06:41 PM
Default Easy
I would just buy a number and fractional drill set to start. Then buy extras of the 5 sizes that are listed. But buy good quality sets.
You are going to need some smaller sizes as a guide hole when drilling out rivets and for tapping, etc
Thank you
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for thier use.
Wings 90%
Old 02-25-2017, 07:03 PM
Hi Ray,
This is just a FWIW, but I limped along for decades with a very small set of bits, occasionally buying special purpose bits needed for various projects. I've always done my own auto, home, electronics, etc maintenance, and I've wasted a lot of time that way.
Not long after I started my -7, I discovered that Harbor Freight offers this:
http://www.harborfreight.com/115-pc-...set-61543.html
I've had that set for over a decade, and they stood up well drilling aluminum, until I started using the bits on really tough stuff like stainless and hardened steel, and for other 'odd jobs' around the house & hangar/shop.
Several years ago, I bought this set:
http://www.harborfreight.com/115-pc-...set-61886.html
I haven't used them a lot, but they do seem like pretty decent bits for the money.
I mention them because, especially with the less expensive set, you'll have any size you're likely to need for not much more money than buying ones & twos of specific bits.
For the highly repetitive jobs (#30 & #40, for instance), it's worthwhile to get a handful of quality bits from a reputable supplier, of course.
The inexpensive sets of 'step bits' from HF also do a decent job in aluminum sheet, and a tolerable job for those rare cases where you need a big hole in stainless (firewall, for instance).
Charlie
Old 02-25-2017, 07:25 PM
Tom023 Tom023 is offline
Plus 33, 34, 21, 1/8, 7/16, 17, I'm sure others
RV14A #140083
Wings, empennage and fuselage slow builds completed
Finish kit in progress
2017 Donation
Old 02-25-2017, 07:41 PM
I'm putting together a McMaster-Carr order and have a dozen of each in the shopping cart. May add a couple each of the sizes that others have mentioned. The second HF fractional & numbered set is a temptation as a good backup for other sizes, especially if I can use one of their coupons.
What's a good source for the 12" bits? McMaster has 12" fractional sizes but not numbered that I can find. Cleaveland doesn't show an image of their 12" bits. I'd prefer a long shank with a short drilling depth. Just seems to me that they would hold up better.
Ray Dosh
LJ45 driver
RV-14 QB #140212
2017 DUES PAID
Marion, IN MZZ
Old 02-25-2017, 08:16 PM
wirejock's Avatar
wirejock wirejock is online now
Default Reamers
I have the HF set. It works fine but the more heavily used bits have been replaced with higher quality bits. However, in my case, every hole is final drilled with a reamer. I highly recommend buying guide a reamer of the more commonly used sizes. #40, #30, #19, #12, 3/16", 1/4" and the oddball, .311".
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-25-2017, 10:14 PM
KeithB KeithB is offline
Maybe I drill out more rivets than most, but I also like a #43 for drilling AN3 rivets and #33 for drilling out AN4 rivets. (I drill the heads with #40/#30, snap them off with a punch, then drill the rivet shaft with #43/#33).
There are also call outs in the plans several others - #17 and #34 come to mind. The Harbor Freight set filled the need.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >180 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 02-25-2017, 11:42 PM
Default Brown tools
Brown Tools ( A VAF advertiser) has all the different bits you would ever want. Try them.
Thank you
John S
Wings 90%
Old 02-26-2017, 07:11 AM
Lots of good information here, guys. Thanks a bunch! Larry, thanks for the reamer idea. I've seen that mentioned before (perhaps by you). I'll look into it.
Ray Dosh
LJ45 driver
RV-14 QB #140212
2017 DUES PAID
Marion, IN MZZ
