Old 02-24-2017, 04:31 PM
Stockmanreef Stockmanreef is offline
Default wiring harnesses for panel?
When do you get the wiring harnesses for the panel? With the finishing kit? Or when you order the avionics you plan to use?
I ordered the finishing kit and just wondering about this issue, since I don't recall the question during ordering.
thanks
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 02-24-2017, 04:59 PM
Arablenz Arablenz is offline
From what I have seen you will get the harnesses from your avionics provider such as Steinair. I am a little confused on the fuselage wiring harness as I saw a post yesterday saying Vans can provide that harness for the RV 14 but I haven't been able to find it on their parts and accessories .
Old 02-24-2017, 05:41 PM
mturnerb mturnerb is offline
https://www.vansaircraft.com/pdf/let...s_P9_Final.pdf
From this document:
"... Common Fuselage Harness
o Description is mentioned above. Harness, aux music jack, power outlet
and instructions for installation to mate to the empennage and wing
root connectors
o Status: Kit is available. Order the “ES WH-00125 Kit”. "
You can also order fuselage harness from SteinAir - I plan to go that route.
Turner Billingsley
RV-14A Fuselage in progress
Old 02-24-2017, 06:14 PM
MED MED is offline
I asked Sterling about the fuselage harness and whether I needed to order it from Van's. He said, if I was ordering from Stein or equivalent, they would provide the harness, including the wiring to the sticks. The Van's harness is available if you want to do it yourself.
Old 02-24-2017, 09:36 PM
Thanks for providing the clarity and part #.
