Old 02-24-2017, 10:33 AM
Default Want to add 2nd PTT Switch
I want to add a second PTT switch on right stick of an early model 12 with Dynon D-180. I have the seat pan out and don't see a specific wire for the right side switch. Should the wire be part of the original wiring harness? The schematic shows a separate wire connecting to the intercom. Any help appreciated...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 320
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-24-2017, 10:40 AM
DaleB's Avatar
DaleB DaleB is offline
I haven't looked specifically at that part of the harness, but mine (also a D180 equipped plane, S/N 120222) I have a co-pilot PTT. The schematic shows it as a white/blue wire on pin 3 of the 37-pin tunnel harness connector.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 02-24-2017, 10:49 AM
Thanks Dale. I'm studying the schematic and it appears that I have to add my own wire all the way from the stick to pin #6 on the intercom. Schematic shows wire as "Blue Dashed" all the way from the stick to the intercom which means optional wire.
Hinckley, Ohio
Old 02-24-2017, 11:03 AM
DaleB's Avatar
Huh. That's not obvious on my PDF copy. I have the original DWG file, and it shows white/blue. The pilot PTT shows white/brown, so they match the wire colors.
Dale
Omaha, NE
Old 02-24-2017, 11:51 AM
Jim have you ever thought of a remote push to talk switch similar to these http://m.skygeek.com/push-to-talk-switch.html ?
Old 02-24-2017, 01:51 PM
Thanks guys. Switch will be permanent mount in top of stick grip to match pilot side. I will open the tunnel tomorrow and see if I can find white/blue and white/brown at the connector.
Hinckley, Ohio
Old 02-25-2017, 10:04 AM
Update - I decided to run a single wire from the right stick all the way up to the #6 pin on the FlightCom. Nice clean installation.
Works swimmingly...
Hinckley, Ohio
Old 02-25-2017, 08:06 PM
yankee-flyer yankee-flyer is offline
Default S/N 120241 (built -n 2010) came with wiring
for PTT (actually, came with 2 PTT) in the kit.
Wayne 120241 N143WM
