Old 03-01-2017, 06:56 AM
BillL BillL is offline
Default Don't cut that yet!!! It is a trick . . .
Originally Posted by Roy25101 View Post
OK... Dremel it is. I'm always looking for an excuse to buy a new tool. Thanks y'all...
Roy, be sure you double check the edge distance on this before you cut to the print. I had to replace mine, many do.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 03-01-2017, 07:40 AM
Flying Canuck Flying Canuck is offline
I don't think I trimmed mine much because I needed the length for placing the rudder pedal as far aft as possible, I just cut out the lightening holes.
If I had trimmed it, it would have been on my band saw. I can cut .040 easily if I have a reasonably new metal cutting blade. The stock wood cutting blade is useless, but blades are pretty cheap and make a huge difference. It works well enough to cut the thick 3/4" bar stock that's to make the canopy wedge spacer.
The Dremel cut off wheel is a great tool though, I've used it lots. I've got through a lot of sandpaper pieces for the drum attachment, very handy in some of the awkwardly placed and sized openings.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Waiting for my registration, then it's final inspection time!
